Old 09-27-2007, 07:15 AM   #1
klcl
klcl is on a distinguished road
Default Oil Leak? Not oil pan, not valve cover, not front oil seal.
96 SL1 (SOHC) auto 95K. This car has a slow oil leak maybe 6 -10 drops that I can see when I park the car after being driven (The oil leak drops near the oil pan drain plug and stops after the 10 drops or so). I redid my valve cover gasket and I am sure that it is sealed good and there is no leaks from the cover. I checked my front oil seal on the passenger wheel side and there is no leak there. I clean off my oil pan so I am pretty certain it is not the oil pan but somewhere above the oil pan and between the valve cover at the back of the engine block. Does anyone know the possible source of the leak? Thanks.
Add to klcl's Reputation
Rate the quality of this post and help klcl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
klcl is offline   Reply With Quote
Old 09-27-2007, 07:43 AM   #2
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Default Re: Oil Leak? Not oil pan, not valve cover, not front oil seal.
My DOHC was leaking oil out of the head gasket. Not a lot but enough to leave a few drops on the ground and coat the backside of the engine. Look where the head meets the block.I fixed it when i did my engine rebuild.
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 09-27-2007, 08:11 AM   #3
klcl
I redid my camcover gasket (head gasket) as per Wolfman's instructions and it is sealed good (no oil when i run my finger along the bottom of gasket):
http://www.saturnfans.com/forums/showthread.php?t=26532
Old 09-27-2007, 08:29 AM   #4
BarnOwl
BarnOwl's Avatar
I'll toss out a few possibilities. The oil pressure sensor can leak, sometimes profusely. There is actually a rubber seal on the oil plug. That might be leaking. Oil filter not tight enough? Timing chain cover? There's always the dreaded rear main seal. It's rare but, the head gasket can leak oil.
Add to BarnOwl's Reputation
Old 09-27-2007, 09:56 AM   #5
klcl
Ok seems like i mixed up my terms here. I redid my valve cover (camcover) gasket but not my head gasket (where the cylinder head meets the engine block). For some reason I thought there were the same. Oil filter and drain plug does not leak. So it appears the head gasket is the most likely source of my leak since the leak is below the valve cover and above the oil pan and only a few drops after it is driven. Would the oil pressure sensor or rear oil seal leak this way?
Old 09-27-2007, 11:05 AM   #6
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
My 97SC1 has the same issue. (129k miles)
I've sealed the cam cover with great care and carefully looked at all potential leak points.
99% sure it's at the front (timing chain end) of the head/block interface.
I'm not going to do anything unless it gets many times worse or I'm into the motor for another reason like a cracked head or cam chain problem.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-27-2007, 11:18 AM   #7
amazinghl
Pressure wash everything and put a oil dye in the oil, then watch for leaks.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 09-27-2007, 12:00 PM   #8
rossao1
rossao1 is on a distinguished road
rossao1's Avatar
2006 ION-3 Sedan
Question Re: Oil Leak? Not oil pan, not valve cover, not front oil seal.
The tranny has "oil" in it also. Look around there to be sure it is not the leak source. Or the intake, oil gets in there from the EGR route. Stranger things can happen.
BTW, how is your oil consuption rate? (qt/miles) 1 qt /per 3000 miles is the factory acceptable rate.
Have you searched the help sections? It is a very powerfull knowlegde collection and discussions. Plus many photos are online from people rebuilding their engines.
I hope this helps.
A Saturn owner since 10/91.
'92 SC, '91 SL2, 95 SW1, '06 ION3
other car- '02 Expedition 5.4L
Add to rossao1's Reputation
Rate the quality of this post and help rossao1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rossao1 is offline   Reply With Quote
Old 09-27-2007, 12:44 PM   #9
If it does, the OP has bigger problems. The tranny should ONLY have ATF. If the leaking substance isn't rosy pinkish red, either (1) it's oil, or (2) the tranny fluid (and, by implication, possibly the tranny) is WAY beyond shot. (Or [3] someone has put gear lube in the manual tranny; it's not unheard of.)
Add to madpogue's Reputation
Old 09-27-2007, 02:47 PM   #10
klcl
Thanks for all the replies. It is definitely not ATF and not leaking around the EGR. Oil consumption is about 1/2 qt every 1000 miles so no real complaints there. I already did a cleaning of the area in question and the leak is in the area above the oil pan and below the valve cover gasket on the backside of the engine closer to the timing chain area so I tend to agree with Bill_Murray and johnny95sl2 that it is the head gasket. So again like Bill_Murray unless it gets a lot worse I guess I will live with it. Those annoying oil drops on the driveway don't look too cool though.
Old 09-27-2007, 04:28 PM   #11
Phredawgy
Phredawgy's Avatar
drip pan....or go buy some cat litter ... alot of places do sell driveway cleaner for that......they can be pretty powerful too....I had a bottle drop out of my hands and splash around...and some got on my shirt...by the time i got home to take it off I had a big red burn on my skin......
Add to Phredawgy's Reputation
Old 09-27-2007, 06:42 PM   #12
eljefino
eljefino's Avatar
1995 SW1
Could be the driver's side of the oil pan; there are lots of braces and stuff in the way of getting a good visual.
Add to eljefino's Reputation
Old 09-27-2007, 10:46 PM   #13
There are also lots of things bolted into the rear side of the block. Oil pressure sender, CPS, etc; IIRC, there are some oil galley plugs threaded down back there.
Old 10-05-2007, 06:06 AM   #14
klcl
Happy Re: Oil Leak? Not oil pan, not valve cover, not front oil seal.
Update. Got some jack stands and got under my car with the engine running and I could clearly see the oil dripping from the oil pressure switch (otherwise referred to as oil sending unit or oil pressure sensor). Replaced the switch ($9 at Advance auto) and no more leaks, very happy and thanks all for the help.
Old 10-05-2007, 11:25 AM   #15
johnholl
johnholl is on a distinguished road
Where is the oil sending unit located? On the firewall side i take it.
I think my consumption is a combination of leaking and burning, I see the oil on the block but no drips on the drivway. I did the MMO soak once
John,
200 miles to the quart [wadiya want for $200.00?] my Wife saves enough on gas driving this car to off-set the cost of 1qt/week
Add to johnholl's Reputation
Rate the quality of this post and help johnholl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnholl is offline   Reply With Quote
Front Crankshaft oil seal leak 1andonly S-Series Tech 6 08-18-2009 04:48 PM
cam gasket? seal? oil pan leak? have pics SL1commuter S-Series Tech 5 03-11-2009 05:48 PM
SL2 oil leak & Rear oil seal kit parts id jimmmm S-Series Tech 1 10-25-2007 01:50 PM
front crankshaft seal oil leak PACT Man S-Series Tech 8 03-31-2006 11:14 PM
advise on oil....ls2's oil drain pan valve juliansdad L-Series General 6 07-31-2003 09:42 PM
