Old 03-16-2021, 11:33 PM   #121
AstraFasta
Default Re: Astra 45k mile service - inexpensive & runs like new!
Originally Posted by tackepj View Post
What code reader do you use for your Astra? Do you recommend it?
I use the ScanGauge2. That is just for monitoring and not diagnosing. It was great 10 years ago but there are better items now.
Old 03-16-2021, 11:36 PM   #122
AstraFasta
For diagnosing P2096 the Astra Service Manual (ID 2006061) steps are linked above. Below summarizes most of the testing I did tonight:
1. Closed loop with engine warmed up shows no obvious clues (ScanGauge2). Car still shows "not ready" for testing as we just cleared the code:
Fuel trims (typical)
ST 0-5
LT 0-5
o2 sensors
B1 0-90%
B2 0-90%
Both -->0 gliding with foot off the gas pedal
Both-->90 accelerating hard
Water temp ~92*C
Barometric pressure ~14.6 PSI
Ambient air temp 35*F
MAF ~5 g/s at idle. ~30 mild acceleration. ~50 hard acceleration
Engine sounds great and is perfectly responsive.
2. Based on the Service Manual, I think next steps to check are:
- EVAP purge valve and vacuum hoses
- Leaking exhaust from HO2S forward (the flex pipe!)
Old 03-17-2021, 10:54 AM   #123
tackepj
tackepj's Avatar
2008 Astra XE
Such as? Just curious. Always wanted to have one on hand but didn't know what would be appropriate.
Current: 2008 Astra XE
Old 03-17-2021, 11:42 AM   #124
AstraFasta
No idea m8. Better scanners provide Saturn-specific codes & can display data real-time on a x-y graph.
Old 03-29-2021, 08:36 PM   #125
AstraFasta
Replaced RH door mirror glass/ heating element/ plastic. That is one part and looks to be good quality overall; the glass is pretty clear and not wavy. Box label stated part was made in Taiwan. Took 30 seconds to install.
Original German seller did not want to ship to US, so purchased from Bulgarian ebay seller maxiarbitrage for under $25 shipped.
FYI - c.2015, the OEM door mirror glass fell off as is typical with the Astras. We replaced just the door mirror glass with an eBay kit that came with 2 sided tape. The replacement was a bit wavy but flattened after a year or so. In 2020, the RH mirror "silver" coating was failing, so large blotches started forming. Hence, the new glass for RH mirror. LH mirror looks fine...for now.
Old 03-30-2021, 11:45 PM   #126
AstraFasta
Replaced 4 plastic roof rack covers with parts from Latvia for about $12 shipped. ebay seller almets_cnc
60 seconds to install all 4. I think the design is clever with big tabs, so I don't see these failing or falling off. The plastic looks to be good quality, flexible, and well molded. Shipping was about 2 weeks.
Roof looks much nicer with these 4 plastic covers (plus we just repainted the 2 metal gutter bars.) Very happy with this upgrade. Goob also received and installed his 4 covers today.
Old 04-03-2021, 06:35 PM   #127
AstraFasta
I think the 4 plastic roof rack covers reduce highway wind noise quite a bit. They don't fit 100% perfectly but are a big improvement over the 4 holes. Good enough for this neighborhood.
P2A01 popped up when we started driving today. Cleared the code and it did not pop up again.
"HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 2 (PCM)"
P2096 popped up last month
"Post Catalyst Fuel Trim System Too Lean Bank 1"
First guess is these are related to the flex pipe. Second guess is rear O2 sensor (although real-time voltage from both 02 sensors seems fine).
http://www.saturnfans.com/forums/sho...d.php?t=219869
50,000 mile service? EdwinM Ion General 4 07-12-2006 03:47 PM
12,000 mile service.......... joejones3rd Vue General 6 03-14-2005 07:58 PM
6,000 mile service bob shanks Vue General 11 02-21-2004 05:53 PM
100,000 mile service on ls2 bobm33 L-Series General 27 02-17-2003 10:03 PM
200,000 mile service? ProDarwin S-Series Tech 7 11-27-2002 06:51 PM
