Old 08-31-2003, 06:04 PM   #1
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Cool Here's my famous cracked Coolant Temp Sensor Scan {ECTS}
This topic comes up every other day.Here's why you need to change this thing,regardless of how well your car runs.This one has only 55,000mi. on it!
A great souviner and conversation piece....
See the cracked ECTS here!
auxmike is offline
Old 08-31-2003, 08:42 PM   #2
DualCamCoupe
DualCamCoupe is on a distinguished road
DualCamCoupe's Avatar
Default Re: Here's my famous cracked Coolant Temp Sensor Scan {ECTS}
Originally posted by auxmike
THere's why you need to change this thing,regardless of how well your car runs.
How often are we talking about?
DualCamCoupe is offline
Old 08-31-2003, 09:20 PM   #3
auxmike
auxmike's Avatar
Default
Well...you want the resin tip out the brass tip in.Should be a one time switch....
See the difference by clicking the link. New vs. old ECTS
auxmike is offline
Old 08-31-2003, 10:09 PM   #4
DualCamCoupe
Default
I don't follow
Old 08-31-2003, 10:17 PM   #5
auxmike
auxmike's Avatar
Default
The brown tipped one's are put in at the plant.They crack,give false readings.The brass tipped ones are....well...BRASS,they won't crack.
auxmike is offline
Old 08-31-2003, 11:00 PM   #6
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
The Brass one is an updated design to eliminate the cracking problem. Once you install the brass one, you shouldn't have to replace it again (or at least not as often as the plastic ones that crack far too often).
Saturn-Eh! is offline
Old 09-01-2003, 07:54 AM   #7
TedL
TedL is on a distinguished road
Default
Sorry if the answer's already posted somewhere, but what years had the resin ECTS from the factory? I'm assuming they changed to brass as OE at some point.
TedL is offline
Old 09-01-2003, 08:13 AM   #8
gdelgrego
gdelgrego is on a distinguished road
2007 AURA XE
1992 SL2
Default
Does anyone know if the brass sensor has a different part # from the plastic one? Mine was changed two years ago by the dealer... part # 21025106. Is it safe to assume they used a brass one? Any way to confirm without pulling it?
Thanks
07 Aura XE
92 SL2
gdelgrego is offline
Old 09-01-2003, 08:48 AM   #9
auxmike
auxmike's Avatar
Default
I bought two brass tipped from SPS in2/03,same pt# as you post.Hopefully when they went to brass they actually changed the p/n...
auxmike is offline
Old 09-01-2003, 10:23 AM   #10
Luke
Luke's Avatar
Default False Readings
Fm Mike
The brown tipped one's are put in at the plant......They crack, give false readings.
In giving false reading to the computer, you'll notice a drop in your miles per gallon reading. You notice it.
Luke is offline
Old 09-01-2003, 02:14 PM   #11
SpeedPlayer 97sl2
SpeedPlayer 97sl2 is on a distinguished road
SpeedPlayer 97sl2's Avatar
Default
I pulled my plastic/composite ECTS the other day, as I was getting horrible gas mileage. Mine had one big crack like your's, and another hairline crack on the other side of the tip. Measured the resistance across the terminals of the sensor cold and hot, and it was within spec. Nonetheless, I imagine a cracked tip would give bad readings anyways.
Your ECTS looks mighty old. Mine's looked almost brand new except for the tip and a couple threads.
My reality check bounced.
SpeedPlayer 97sl2 is offline
Old 09-01-2003, 02:52 PM   #12
auxmike
auxmike's Avatar
Default
Mine's from a '97 as pictured.I guess the heat/elements age stuff faster...
auxmike is offline
Old 09-01-2003, 03:03 PM   #13
SpeedPlayer 97sl2
Default
Mine's is also from a 97 with 59K miles on it.
Old 09-01-2003, 03:08 PM   #14
auxmike
auxmike's Avatar
Default
I'm in NY.Harsh winters,road salt,owner before me probably did little maint to cooling system,etc.Cars up here take a beatin'.....
auxmike is offline
Old 09-01-2003, 05:25 PM   #15
BWhite
BWhite is on a distinguished road
Default
Great pics Mike . they go a long way explaining the problem
BWhite is offline
Old 09-01-2003, 06:10 PM   #16
100KSW2
100KSW2 is on a distinguished road
100KSW2's Avatar
Default
Two questions:
1) Do you have to drain the coolant to check this part?
2) What does the replacement part cost (ballpark figure)?
Thanks!
I am fairly sure that mine is original (at 112K+ miles and 10+ years).
100KSW2 is offline
Old 09-01-2003, 07:34 PM   #17
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
1) Best just to replace it rather than checking if you can't remember it ever being changed because:
2)It's only about $15-$20
The sensor is located on the driver's side of the cylinder cylinder head, a little behind and below the upper rad hose. The electrical connector is removed by squeezing it on it's high points. Relieve pressure in the cooling system by undoing the pressure cap, then re-tighten the pressure cap and undo the sensor. A little coolant will dribble out while you switch sensors. tighten the new sensor to 18-ft lbs, or snug - the sensor has thread sealant, and is tapered, so it's hard to mess up and cause a leak.
PS DO THE ABOVE ON A COLD ENGINE! DON'T BURN YOURSELF!
Old 09-01-2003, 10:49 PM   #18
Luke
Luke's Avatar
Default
Fm BWhite
I'll strongly "second" that....
Luke is offline
Old 09-01-2003, 10:53 PM   #19
auxmike
auxmike's Avatar
Default
My pleasure folks.Just takin' care of "family".
auxmike is offline
Old 09-02-2003, 12:30 AM   #20
DualCamCoupe
Default
Is there any way of knowing if your car already has a brass one without pulling it out? At what point did they move to brass?
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
Changing the ECTS Coolant Temp Sensor (with pictures) auxmike How-To Library 43 10-02-2005 02:51 AM
Ref Mike's "How-To" : Change the ECTS Coolant Temp Sensor w/pics! Luke S-Series Tech 2 06-20-2005 02:19 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
cracked ects & green coolant satwag Miscellaneous Tech 16 04-08-2004 04:43 PM
