Old 06-04-2009, 04:55 PM   #1
sleepersatty99
sleepersatty99 is on a distinguished road
Default Engine coolant temp sensor?
What would be a good way to tell if your engine coolant temp sensor is going bad or is bad?
sleepersatty99 is offline   Reply With Quote
Old 06-04-2009, 07:06 PM   #2
rc1488
rc1488's Avatar
Default Re: Engine coolant temp sensor?
Really??
Use the search button for the 34253425342543252 posts on the ECTS.
Old 06-04-2009, 07:09 PM   #3
sleepersatty99
Originally Posted by rc1488 View Post
Really??
Well now its 34253425342543252 + 1.
Old 06-04-2009, 07:11 PM   #4
rc1488
rc1488's Avatar
Nope i included your post in my original number
Old 06-04-2009, 07:19 PM   #5
sleepersatty99
lol. well thanks for some reason i didnt think to use the search button.
Old 06-05-2009, 08:51 AM   #6
DonP
1. Physical examination.
2. On a '99, erratic or unexpected behavior of the temp gauge.
In general,if it is the original type, replace it because it will fail, it is just a matter of time.
You can spot the original type from the exterior profile, There are pictures in some threads the show the difference.
Old 06-06-2009, 01:26 AM   #7
DIYguy
DIYguy's Avatar
Wrench Re: Engine coolant temp sensor?
Original ECTS= Amber colored plastic for the entire sensor including the body and the connector. Original = bad, period.
Newer style ECTS= Brass body (look at the wrench flats). Newer = maybe good. Look for greenish corrosion or goo in the sensor's connector and in the wiring harness connector. If found in either place, replace both pieces. Do not bother trying to clean either one of their connectors.
If replacing them-
New sensor- $12-$15 at Autozone or equivalent. Get a Niehoff brand if possible or get it from Saturn (more $$$).
New connector- Clip off an IAT conenctor and wires from a junked car (same connector style) or buy one from Saturn ($35), or use a 2 pin connector from an old computer case that was used for a front panel LED. The ECTS connections are 0.025" square pins (two of them) on 0.100" centers. If you use the computer connector, wrap some electrical tape around it and the ECTS to keep moisture out.
Hope I helped.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn (gone but never forgotten), Gen6 Camaro, Cruze Eco, Chevy SS P/U, Honda VT1100C, Honda CBX
Old 06-06-2009, 08:24 PM   #8
sleepersatty99
If replacing them-
Hope I helped.
does the ects look like the IAT? yeah im going to replace it.
Old 06-06-2009, 09:06 PM   #9
It's the same part. It doesn't fail in its commission as an IAT sensor because it's not bathed in hot coolant.
Recommended Tool for Replacing Engine Coolant Temp Sensor richpin06 S-Series General 3 07-10-2009 09:31 AM
Information Center (DIC) Engine temp or Coolant Temp ? Astrafirstsatur Astra Tech 10 02-16-2009 09:10 AM
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
engine coolant temp sensor skijay S-Series Tech 10 04-30-2003 10:19 PM
