Old 06-18-2005, 06:54 PM   #1
dcp
dcp is on a distinguished road
dcp's Avatar
Default trans-axel seal
I need help pulling a transaxel seal from the case.I have discovered there is a snap-ring on the out side of the seal,but I dont see the holes for the tool,I have got every thing else tore apart,out of way.also is there any thing i need to know to have a good job assemble?The seal was leaking.it is on drivers sideThank you for addvice 98sl2
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 06-18-2005, 07:17 PM   #2
wolfman
wolfman's Avatar
Default Re: trans-axel seal
Use a very small blade screw driver to pry one end of the snap ring out of the groove and then work it out of the groove. It is hard to break so don't be too afraid to work at it a bit. I have found that two small blade screw drivers will do the trick with a bit of patience. Since you will be replacing the seal anyway, a "hook" type seal puller or large screw driver can then be used to pry out the seal. Once the old seal is out, cut the rubber lip off and then use the old seal and a large socket to drive in the new one until bottomed in the bore. You'll know when its' seated as the snap ring will not reinstall until it is.
Add to wolfman's Reputation
Old 06-18-2005, 08:41 PM   #3
dcp
dcp's Avatar
Thankyou wolfman I was hoping you would respond!
Old 06-20-2005, 09:45 AM   #4
Luke
Luke's Avatar
Default Think Dental Tools/picks
> Wolfman <
> Use a very small blade screw driver to pry one end of the snap ring out of the groove and then work it out of the groove. It is hard to break so don't be too afraid to work at it a bit. I have found that two small blade screw drivers will do the trick with a bit of patience. <
Or a dental tool; those teeth tools work very well.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 06-20-2005, 12:54 PM   #5
dcp
dcp's Avatar
I did use the dental tool it worked great!thanks
Trans Axel Dip Stick kinda loose? l0phat S-Series Tech 4 11-28-2009 04:01 PM
Axel seal replacement bigbfarm S-Series Tech 0 09-09-2009 03:26 PM
Axle/Trans seal Seepage-Squeal Ls1Junky S-Series Tech 6 12-11-2008 01:14 PM
TAM replacement (Trans-axel mount) JS593 S-Series General 10 09-14-2005 05:21 PM
Trans-Axel question dcp S-Series Tech 2 06-20-2005 09:54 PM
