Old 05-04-2010, 12:19 AM   #1
mjoekingz28
mjoekingz28 is on a distinguished road
Default Grease
I know Saturns (ball joints and tie rods) come sealed for life as the window sticker says, but my Dad's F150 doesn't have grease fittings either as they are sealed for life. Not long ago, every time his suspension would compress/decompress it would squeak. He got what he described as a basketball needle and injected grease into the rubber boots and now it doesnt squeak anymore. Saved him big bucks.
I want to be pro active and do this (if possible) before it starts squeaking and maybe avoid replacement of these parts.
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 05-04-2010, 08:02 AM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Grease
that makes sense but doesnt the grease end up coming out of the hole put in the rubber boot?
Add to onefunkar's Reputation
Old 05-04-2010, 08:20 AM   #3
Default Re: Grease
No, you use the needle to inject the grease into the area under the boot either by going in next to the ball stud or under the outer edge. If its real tight there is a 16 gauge hypodermic that you can get and that makes a self sealing hole. The problem is that all greases are not compatible with each other. You have to know what is in there to start with.
Old 05-04-2010, 02:57 PM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Grease
sounds like a good idea. didnt know you could do that.
Old 05-05-2010, 07:23 AM   #5
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: Grease
You really can't. Actually a sealed ball joint (as long as the seal is not broken will last longer than a greasable in my experience. Bottom line putting a needle in a sealed ball joint or tie rod end is NOT a good idea. And believe me if it's squeaking it's shot anyway
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Old 05-05-2010, 08:08 AM   #6
Default Re: Grease
You have to lube them before they squeak with the proper lubricant. Determining the proper lubricant is the issue. If you can find out what to lube them with periodic lubrication will extend the service life. Usually only one relube is effective in extending teh service life.
Grease on rubber mjoekingz28 S-Series Tech 1 08-14-2009 09:15 AM
white lithium grease can be used as brake caliper grease? microsat S-Series General 9 09-18-2007 02:19 PM
Grease job on an Ion? Blueshark Ion Tech 2 02-11-2007 09:31 AM
Grease From AC Clutch andy2049 S-Series Tech 5 11-01-2006 08:27 PM
Use of dielectric grease PeteB S-Series Tech 9 09-22-2005 09:32 PM
