Old 09-17-2007, 06:37 PM   #1
microsat
microsat is on a distinguished road
Default white lithium grease can be used as brake caliper grease?
I have lithium grease. Now I want to change my rotor. Can the lithium grease be used as dielectric silicone grease which is required on my manual for replacing rotor?
Add to microsat's Reputation
Rate the quality of this post and help microsat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
microsat is offline   Reply With Quote
Old 09-17-2007, 06:55 PM   #2
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Default Re: white lithium grease can be used as brake caliper grease?
I'm confused. I changed my rotor, but didn't mess with the pads or calipers or anything. I didn't have any point that I needed grease, but I know when you change pads you need it. Dielectric silicone grease is used on spark plug wires, because it transmits electricity. Maybe it's used on rotors, too.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 09-17-2007, 07:28 PM   #3
ringed1
ringed1 is on a distinguished road
1994 SC2
The rotors can be changed by just removing the caliper assembly (remove the two bolts that attach the caliper to the steering knuckle). You don't have to remove the guide or lock pins to do this, but if you do, don't use white lithium on them. You'll need high-temperature grease specifically formulated for use with the calipers.
Add to ringed1's Reputation
Rate the quality of this post and help ringed1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ringed1 is offline   Reply With Quote
Old 09-17-2007, 11:05 PM   #4
microsat
Are you really sure? how to use c-clamp to correct the caliper?
Old 09-18-2007, 09:16 AM   #5
BarnOwl
BarnOwl's Avatar
You use the C-clamp to shove the piston back into the caliper. If you aren't doing pads, this isn't strictly necessary but, it'll make things easier. Sometimes I'll confess to using a giant set of channel locks to do the calipers. It's faster and I don't have to go hunting my C-clamps.
Add to BarnOwl's Reputation
Old 09-18-2007, 09:35 AM   #6
AJT_Leo
AJT_Leo is on a distinguished road
AJT_Leo's Avatar
When I replaced the rotors and pads, I just used my thumbs to push in the calipers. It was probably slower than clamps, but easy nonetheless.
The bureaucracy is expanding to meet the needs of the expanding bureaucracy.
Add to AJT_Leo's Reputation
Rate the quality of this post and help AJT_Leo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AJT_Leo is offline   Reply With Quote
Old 09-18-2007, 09:41 AM   #7
Hipster
Hipster is on a distinguished road
Hipster's Avatar
Unless of course you are replacing rear ABS disk pads. They are screwed in.
I like channel locks also-quicker.
'95 SL2 "Little Beast" (Kids like the name)
Rebuilt motor
"Big Beast" is a '03 F150 gas hog for boat towing/ice fishing
Add to Hipster's Reputation
Rate the quality of this post and help Hipster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hipster is offline   Reply With Quote
Old 09-18-2007, 09:50 AM   #8
AJT_Leo
AJT_Leo's Avatar
Correct. For the rear rotors and pads, with the abs calipers I used needle nose pliers to rotate the caliper until is went down.
Old 09-18-2007, 10:10 AM   #9
froggy81500
froggy81500 is on a distinguished road
2006 ION-2 Sedan
Lithium grease is typically not for high heat applications. Something designed to withstand high temps of brake systems you should use. A good anti-seize will do both, keep parts from seizing together and work as a brake lube. Its all I usually use when doing brakes. Its designed for high heat also.
I've got a bottle of this:
http://www.partsamerica.com/ProductD...egoryCode=3287
Which I used on my last brake job last summer on my previous car.
Add to froggy81500's Reputation
Rate the quality of this post and help froggy81500 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
froggy81500 is offline   Reply With Quote
Old 09-18-2007, 03:19 PM   #10
97coupe
97coupe is on a distinguished road
I use a light film of moly grease on pins. Even if the "vehicle" in grease dries out from heat bake it leave moly behind. It works well. I have been doing it for over 20 years and I have yet to have any stuck pin/bolt issues using it. Never been a big anti seize compound fan.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Grease on rubber mjoekingz28 S-Series Tech 1 08-14-2009 10:15 AM
White grease + electrons = ? jarl S-Series Tech 5 11-10-2008 02:13 PM
Grease From AC Clutch andy2049 S-Series Tech 5 11-01-2006 09:27 PM
White Lithium Grease spray for lube? Jerry_Strn Miscellaneous Tech 2 12-06-2004 12:39 PM
dielectric grease?... LI 350 Miscellaneous Tech 3 09-15-2001 05:54 AM
