Old 10-25-2010, 02:26 PM   #1
Default '92 header downpipe/flexpipe
When new (such as walker part# 44539), does it come with all the hanger hardware or just the portion that's directly welded to the pipe?
IIRC the stock down-pipe has a "tab" thats welded to the pipe (just ahead of the flex-joint), then the hanger is bolted to that tab with 2 bolts and the other end of it bolts to the engine/transmission brace.
Not sure how, right now, to hang it without that intermediary piece if the new down-pipe doesn't come with it. Don't think I've got any scrap metal that'd do the job laying around...
Either I misinterpreted the ad...or there's another box coming that isn't mentioned w/ the single USPS tracking number I got.
Old 10-25-2010, 02:57 PM   #2
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Default Re: '92 header downpipe/flexpipe
It only comes with the part welded to the pipe. The rest of the hanger is on your car and is reusable.
johnny95sl2 is offline   Reply With Quote
Old 10-25-2010, 05:17 PM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
When I installed the header on my '95 automatic, I didn't get the hanger from the pick-n-pull so I made my own--it was quite simple. I don't recall exactly what I did, but I believe I just attached a small metal angle to the included bracket on the downpipe (such that it went up a bit, then turned and went horizontal), and drilled a hole in the horizontal part, lining up with one of the vertical bolts in the transmission case, and just stuck it on the bolt (as one would put a washer).
Old 10-26-2010, 06:22 AM   #4
Not when your car came with the stupid California emission log manifold stock.
That's an idea, will have to try it. Thanks.
downpipe/flexpipe woes GmG S-Series Tech 2 08-08-2008 01:32 AM
Is the SC1/SC2 downpipe/flexpipe assembly interchangeable? crapboxsaturn S-Series General 1 02-23-2008 12:35 PM
hotshot flexpipe/downpipe replacement feedbacker S-Series General 1 07-10-2006 02:47 PM
WANTED: 96 SC2 downpipe/flexpipe Skatesmo Classifieds 2 01-15-2006 02:30 AM
FS: Downpipe, Grey Header with Downpipe, and Gen II CD Radio amazinghl Classifieds 2 05-11-2004 07:10 PM
