Old 08-04-2009, 12:39 PM   #1
adonalds
adonalds is on a distinguished road
Default rough idle on 2000 sl1
Hi, My daughter's 2000 SL1 idles rough for a few seconds after startup. I have already replaced the intake gasket, plugs and wires. Any ideas? The car has 160,000 miles
Add to adonalds's Reputation
Rate the quality of this post and help adonalds reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adonalds is offline   Reply With Quote
Old 08-04-2009, 12:45 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: rough idle on 2000 sl1
Replaced the ECTS yet? Cleaned the throttlebody? If you haven't done either of those, do both. Even if it's not the cause of the problem (either of which could be), it's good maintenance.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 08-04-2009, 03:31 PM   #3
adonalds
I have changed the ets, but have not cleaned the throttle body. I will try that--thank you
Old 08-04-2009, 10:26 PM   #4
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Are you on the origional fuel filter? It's likely due if it's origional. The brands recommended around here are Wic and the dealer one. Easy to swap and ther is a video in the how-to section.
If you hit the forum search you can find how to get a pressure tester and diagnose.
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 08-05-2009, 08:17 AM   #5
adonalds
I'm not sure if the fuel filter has been changed, but I will check it. Thanks for your help.
Old 08-05-2009, 09:29 AM   #6
OnDaGround
OnDaGround's Avatar
1993 SC2
The likelihood of that being the cause of the issue isn't as likely, but it would still be a good idea if it hasn't been changed in a long time. Especially if you cannot remember if it was ever done.
Saturnless...
Old 08-06-2009, 03:13 AM   #7
sl1driver
sl1driver is on a distinguished road
Another thing that may help is to take your EGR valve off and make sure the pintle is moving freely, and give it a good cleaning.
Andy
2000 SL1 5 speed - 149k and still going strong. Slight oil usage.
New Intake Manifold Gasket, Clutch, Ects, Thermostat, IAC, TPS
Add to sl1driver's Reputation
Rate the quality of this post and help sl1driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl1driver is offline   Reply With Quote
Old 08-06-2009, 04:10 AM   #8
quantumech
quantumech is on a distinguished road
I've had a rough idle on mine too. I've done what these folks have suggested so far with the cleaning and what-not, but it still persists. I took a reading of my manifold vacuum and found that it was good, but rapidly fluctuating between a couple psi on either side. The gauge should read a steady value all the time. It was suggested that I might either have a stuck intake valve or a burnt exhaust valve. I've done a straight-up techron treatment through the PCV connection to try and clean up the valve, and that's helped out with my power, but the rough idle is still there (actually seems to have gotten worse). I need to do a compression test next to see if I do indeed have a burnt valve (which will be a new thread...probably...need the new job to kick in before I can get one).
Not sure if you'll have to go this far, and I would definitely try the above suggestions, but just keep the possibility back the corner of your mind before going crazy and changing all sorts of different parts.
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
97 Sl1 Rough Idle Warm Only francz S-Series General 11 03-10-2013 08:43 PM
2000 s series - rough idle tjall S-Series Tech 1 03-29-2009 08:26 PM
SL1 rough idle Gadweller S-Series Tech 12 05-04-2008 04:50 PM
New to Forum... Please help!! rough idle and shifting 2000 LS2 V-6 mmendez L-Series General 4 03-07-2008 11:37 AM
Help, 01 SL1 rough Idle underfire S-Series General 8 11-29-2007 10:31 PM
