Old 05-29-2018, 09:46 PM   #1
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Default Alignment with lowering springs
I ordered the Megan springs for the RL as the OEM suspension is garbage at this point in its life. Can anyone confirm if you can simply align the car to OE specs or if its necessary to slot the strut holes to get it back in spec?
Thanks guys.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 05-31-2018, 10:49 PM   #2
atikovi
Default Re: Alignment with lowering springs
RL is already lowered from the factory. Go much lower and the tires will rub. The Megan site just lists lowering springs for the Vue with no mention of the Redline. I assume they lower a regular Vue the same as what a Redline is already. The OEM suspension on any older high mileage vehicle is going to be trashed. Just replacing the struts and control arms will make it feel like new.
Add to atikovi's Reputation
Old 08-23-2018, 03:19 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
... You need to get the alignment cam for the to replace the top bolt for alignment, just my .02, dc.
Add to Vue6's Reputation
Rate the quality of this post and help Vue6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-23-2018, 03:20 PM   #4
Vue6
Vue6's Avatar
2006 VUE Red Line
... Sorry typing to fast , you need 2 alignment bolts to replace each top factory ones, they have a cam in them to align, dc.
Old 09-25-2018, 09:07 AM   #5
AlexofNazareth
2002 SL1
2006 VUE Red Line
I guess following up with this, the car already had the cammed alignment nuts and bolts on it. Firestone didnt have problems getting it within spec.
Maybe just as a FYI, with the Megan springs and the heavier duty Gas-A-Just shocks from the Equinox, the rear didn't drop very much [The front did drop an inch]. This pitches the vehicle forward some which causes a need to adjust the headlights up.
Overall the springs with the struts/shocks I chose are pretty good. Cornering is decent for an SUV, but I'm gonna modify the rear swaybar mounts to use a 32mm ZL1 bar to help the car want to rotate more easily.
'06 Vue RL
Wheel Alignment with Lowering Springs snakes Ion Tech 17 06-22-2010 11:26 AM
Camber kit and Alignment when lowering 95_SC2_Guy S-Series Tech 4 08-14-2005 11:01 AM
lowering springs r_o__ Mods and Performance 7 01-13-2003 06:08 PM
lowering springs Saturn3dr99 Mods and Performance 10 06-21-2002 12:24 PM
