#1 |
Body Codes:
DTC B0001 PCM Discrete Input Speed Signal Error DTC B0004 PCM Discrete Input Speed Signal Not Present DTC B0005 In Park Switch Circuit Malfunction DTC B0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low DTC B0017 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open DTC B0018 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range DTC B0022 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low DTC B0024 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range DTC B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open DTC B0028 RF/Passenger Side Deployment Loop Resistance Low DTC B0029 RF/Passenger Side Deployment Loop Open DTC B0030 RF/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range DTC B0035 ADS Closed/Shorted to Ground DTC B0036 ADS Open/Missing/Shorted to Battery DTC B0037 AUX switch closed/shorted to ground DTC B0038 AUX switch open/shorted to battery DTC B0040 LF/Driver Side Deployment Loop Resistance Low DTC B0041 LF/Driver Side Deployment Loop Open DTC B0045 LF Side Deploy Loop Short to Ground/Voltage Out of Range DTC B0051 Deployment Commanded DTC B0053 Deployment Commanded with Loop Malfunctions Present DTC B0057 RF/Passenger Pretensioner Deployment Loop Resistance Low DTC B0058 RF/Passenger Pretensioner Deployment Loop Open DTC B0059 RF/Passenger Pretensioner Deployment Loop Short to Ground/Voltage Out of Range DTC B0064 LF/Driver Pretensioner Deployment Loop Resistance Low DTC B0065 LF/Driver Pretensioner Deployment Loop Open DTC B0066 LF/Driver Pretensioner Deployment Loop Short to Ground/Voltage Out of Range DTC B0073 Supplemental Deployment Loop #1 Resistance Low DTC B0074 Supplemental Deployment Loop #1 Open DTC B0075 Supplemental Deployment Loop #1 Short to Ground/Voltage Out of Range DTC B0077 LF/Driver SIS Malfunction DTC B0078 RF/Passenger SIS Malfunction DTC B0079 Incorrect LF/Driver SIS Installed DTC B0080 Discard LF/Driver SIS DTC B0081 Incorrect RF/Passenger SIS Installed DTC B0082 Discard RF/Passenger SIS DTC B0086 Supplemental Deployment Loop #2 Resistance Low DTC B0087 Supplemental Deployment Loop #2 Open DTC B0088 Supplemental Deployment Loop #2 Short to Ground/Voltage Out of Range DTC B0090 Active switch voltage out of range DTC B0091 Active switch: wrong state DTC B0092 PPS passenger detection error DTC B0093 PPS/CPS self-test malfunction DTC B0094 CPS child seat detection error DTC B0095 SDM-PPS/CPS mismatch malfunction DTC B0126 Right Panel Discharge Temperature Fault DTC B0131 Right Heater Discharge Temperature Fault DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance DTC B0169 In-car Temp Sensor Failure (passenger -not used) DTC B0174 Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance DTC B0179 Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance DTC B0184 Solar Load Sensor #1 CKT Range DTC B0189 Solar Load Sensor #2 CKT Range DTC B0248 Mode Door Inoperative Error DTC B0249 Heater/Defrost/AC Door Range Error DTC B0268 A/I Door Inoperative Error DTC B0269 Air Inlet Door Range Error DTC B0408 Temperature Control #1 (Main/Front) Circuit Malfunction DTC B0409 Air Mix Door #1 Range Error DTC B0419 Air Mix Door #2 Range Error DTC B0423 Air Mix Door #2 Inoperative Error DTC B0428 Air Mix Door #3 Inoperative Error DTC B0429 Temperature Control #3 Rear Circuit Range/Performance DTC B0510 RH Panel Discharge Temp Sensor Failure DTC B0515 RH Heater Discharge Temp Sensor Failure DTC B0520 Rear Discharge Temp Sensor Failure DTC B0530 Fuel Level Sensor Stuck DTC B0532 Fuel Sensor Shorted To Ground DTC B0533 Fuel Sensor Open/Shorted To B+ DTC B0688 Security System Indicator Circuit High DTC B0768 Service Indicator Circuit High DTC B0846 +5 Volt Reference Out of Range DTC B0856 Battery 2 Out of Range DTC B1000 ECU Malfunction DTC B1001 Option Configuration Error DTC B1004 Keep Alive Memory (KAM) DTC B1007 EEPROM Write Error DTC B1009 EEPROM Checksum Error DTC B1013 ROM Checksum Error DTC B1014 Program ROM Checksum Error DTC B1015 Passenger Deploy. Loop Resistance High DTC B1016 Passenger Deployment Loop Resistance Low DTC B1017 Passenger Deployment Loop Open DTC B1018 Passenger Deployment Loop Short to GND DTC B1019 Passenger Deploy. Loop Short to Voltage DTC B1021 Driver Deployment Loop Resistance High DTC B1022 Driver Deployment Loop Resistance Low DTC B1024 Driver Deployment Loop Short to Ground DTC B1025 Driver Deployment Loop Short to Voltage DTC B1026 Driver Deployment Loop Open DTC B1035 Discr. Sensor Closed or Short to GND DTC B1036 Discr. Sensor Open or Short to Voltage DTC B1051 Frontal Air Bag and Preten Deployment DTC B1053 Deployment Commanded w/Loop Malfunction DTC B1054 Infl Rst IP Module Switch CKT Failure DTC B1061 Lamp Circuit Failure DTC B1071 Internal SDM Failure DTC B1115 Passenger Deploy. Loop Resistance High DTC B1116 Passenger Deploy. Loop Resistance Low DTC B1117 Passenger Deployment Loop Open DTC B1121 Driver Deployment Loop Resistance High DTC B1122 Driver Deployment Loop Resistance Low DTC B1124 Driver/Pass. Deploy. Loop Short to GND DTC B1125 Driver/Pass Deploy Loop Short to Voltage DTC B1126 Driver Deployment Loop Open DTC B1131 Pass. Pretensioner Loop Resistance High DTC B1132 Pass. Pretensioner Loop Resistance Low DTC B1134 Passenger Pretensioner Loop Open DTC B1135 Discr. Sensor Closed or Short to GND DTC B1136 Discr. Sensor Open or Short to Voltage DTC B1141 Driver Pretensioner Loop Resistance High DTC B1142 Driver Pretens. Deploy. Loop Res. Low DTC B1144 Driver/Pass Pretens. Loop Short to GND DTC B1145 Driver/Pass Pretens. Loop Short to Volt DTC B1146 Driver Pretensioner Loop Open DTC B1147 Driver Side Air Bag System Malfunction DTC B1148 Pass. Side Air Bag System Malfunction DTC B1151 Deployment Commanded - Frontal DTC B1152 Data Area Full DTC B1153 Deployment Commanded w/Loop Malfunction DTC B1155 SDM Calibration Mismatch DTC B1159 Loss of Serial Data-Key Not Received DTC B1160 Loss of Serial Data - VIN Not Received DTC B1161 Lamp Circuit Failure DTC B1163 Loss of Serial Data-No Lamp Response DTC B1171 Internal SDM Failure DTC B1245 CD Changer Not Responding DTC B1271 Theft Lock Enabled DTC B1310 Ambient Air Temperature Sensor Failure DTC B1311 Outside Air Temp Sensor Short Circuit DTC B1312 High Side Temp Sensor Open Circuit DTC B1313 High Side Temp Sensor Short Circuit DTC B1314 Evaporator Inlet Temp Sensor Open CKT DTC B1315 Evaporator Inlet Temp Sensor Short CKT DTC B1316 In Car Temperature Sensor Open Circuit DTC B1317 In Car Air Temperature Sensor DTC B1318 LH Sun Load Sensor Fault DTC B1319 Sunload Sensor Short Circuit DTC B1321 A/C Low Side Temperature Sensor Fault DTC B1324 A/C Refrigerant Overpressure DTC B1327 Device Power Circuit Low DTC B1328 Device Power Circuit High DTC B1328 RH Sun Load Sensor Fault DTC B1330 Left A/C Discharge Sensor Fault DTC B1331 Right A/C Discharge Sensor Fault DTC B1332 Left Heater Discharge Sensor Fault DTC B1333 Right Heater Discharge Sensor Fault DTC B1340 Air Mix Door One Movement Fault DTC B1341 Air Mix Door Two Movement Fault DTC B1343 Air Inlet Door Movement Fault DTC B1344 HTR/DEF/AC Door Movement Fault DTC B1347 Very Low A/C Refrigerant Warning DTC B1348 Very Low A/C Refrigerant Pressure DTC B1350 Engine Coolant Over-Temperature DTC B1390 Device Voltage Reference Input CKT Malf DTC B1396 Device Voltage Reference Output 1 Circuit Range Performance DTC B1399 Loss of KDD Communications DTC B1422 Device Power Moding Malfunction DTC B1438 IPC High Voltage Output Overcurrent to IPM DTC B1513 Charging System Volts Low DTC B1514 Charging System Volts High DTC B1552 Keep Alive Memory (KAM) Error DTC B1556 IPC EEPROM Odo/Configuration Error DTC B1557 EEPROM Calibration Error DTC B1558 BCM EPROM Checksum Error DTC B1586 Mirror Horiz. Pos Sensor-Out of Range/Open DTC B1591 Mirror Vert. Pos Sensor-Out of Range/Open DTC B1652 Loss of Keep Alive Memory (KAM) DTC B1656 EEPROM Write Error DTC B1658 EEPROM Checksum Error DTC B1697 Mirror Switch Input Shorted to Ground DTC B1698 Mirror Switch L Up Input Stuck High Continued NEXT POST----------------------------------------------------
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#2 |
CONT:
DTC B1702 Mirror Switch Input Shorted to Ground DTC B1703 Mirror Switch L Down Input Stuck High DTC B1707 Mirror Switch Input Shorted to Ground DTC B1708 Mirror Switch R Up Input Stuck High DTC B1712 Mirror Switch Input Shorted to Ground DTC B1713 Mirror Switch R Down Input Stuck High DTC B1717 Mirror Power Fold Control Switch Shorted Low DTC B1713 Mirror Switch R Down Input Stuck High DTC B1718 Power Folding Mirror Switch Input Circuit High DTC B1735 Driver Seat Front Up Switch CKT Malf DTC B1740 Driver Seat Front Down Switch CKT Malf DTC B1745 Driver Seat Rear Up Switch CKT Malf DTC B1750 Driver Seat Rear Down Switch CKT Malf DTC B1755 Driver Seat Asm Forward Switch CKT Malf DTC B1760 Driver Seat Asm Rearward Switch CKT Malf DTC B1760 CD Changer Not Responding DTC B1780 Theft Lock Enabled DTC B1805 Ignition Switch Problem DTC B1815 Driver Recline Forward Switch CKT Malf DTC B1820 Driver Recline Rearward Switch CKT Malf DTC B1825 Driver Recline Sensor CKT Malfunction DTC B1830 Driver Lumbar Forward Switch CKT Malf DTC B1835 Driver Lumbar Rearward Switch CKT Malf DTC B1840 Driver Lumbar Up Switch CKT Malf DTC B1845 Driver Lumbar Down Switch CKT Malf DTC B1850 Driver Lumbar Horiz Sensor CKT Malf DTC B1860 Driver Lumbar Vert Sensor CKT Malf DTC B1870 Driver Belt Tower Up Switch CKT Malf DTC B1875 Driver Belt Tower Down Sw CKT Malf DTC B1900 Driver Belt Tower Vert Sen CKT Malf DTC B1910 Generator L-Terminal Open Circuit DTC B1911 Generator L-Terminal Problem DTC B1913 Heated Seat Switch - Mode Input Shorted to Battery DTC B1918 Heated Seat Switch - Temperature Input Shorted to Battery DTC B1970 Exterior Lamp Power DTC B1971 Inadvertent Power DTC B1972 Low Power Driver Fault DTC B1973 High Power Control Fault DTC B1981 Battery Voltage Low DTC B1982 Device Power Circuit High DTC B1983 Device Power Circuit Low DTC B2101 Recline Aft Switch Failed DTC B2102 Recline Forward Switch Failed DTC B2103 Rear Vertical Down Switch Failed DTC B2104 Rear Vertical Up Switch Failed DTC B2105 Horizontal Aft Switch Failed DTC B2106 Horizontal Forward Switch Failed DTC B2107 Front Vertical Down Switch Failed DTC B2108 Front Vertical Up Switch Failed DTC B2109 Lumbar Aft Switch Failed DTC B2110 Lumbar Forward Switch Failed DTC B2111 Lumbar Down Switch Failed DTC B2112 Lumbar Up Switch Failed DTC B2115 Recline Sensor Failed DTC B2116 Rear Vertical Sensor Failed DTC B2117 Horizontal Sensor Failed DTC B2118 Front Vertical Sensor Failed DTC B2119 Lumbar Forward/Aft Sensor Failed DTC B2120 Lumbar Up/Down Sensor Failed DTC B2130 Driver Memory 1 Select Switch Circuit Malfunction DTC B2131 Driver Memory 2 Select Switch Circuit Malfunction DTC B2132 Driver Memory Exit Exit/Off Switch Circuit Malfunction DTC B2133 Driver Memory Set Switch Circuit Malfunction DTC B2140 Mirror Up Control Switch Circuit Malfunction DTC B2141 Mirror Down Control Switch Circuit Malfunction DTC B2142 Mirror Left Control Switch Circuit Malfunction DTC B2143 Mirror Right Control Switch Circuit Malfunction DTC B2144 Left Front Mirror Vertical Position Sensor Circuit Low DTC B2145 Left Front Mirror Vertical Position Sensor Circuit High DTC B2146 Left Front Mirror Horizontal Position Sensor Circuit Low DTC B2147 Left Front Mirror Horizontal Position Sensor Circuit High DTC B2148 Right Front Mirror Vertical Position Sensor Circuit Low DTC B2149 Right Front Mirror Vertical Position Sensor Circuit High DTC B2150 Right Front Mirror Horizontal Position Sensor Circuit Low DTC B2151 Right Front Mirror Horizontal Position Sensor Circuit High DTC B2175 Tilt/Telescope Module Manual Switch Fail DTC B2200 LF Window Switch Stuck in Up Position DTC B2201 LF Window Switch Stuck in Down Position DTC B2202 RF Window Switch Stuck in Up Position DTC B2203 RF Window Switch Stuck in Down Position DTC B2204 LR Window Switch Stuck in Up Position DTC B2205 LR Window Switch Stuck in Down Position DTC B2206 RR Window Switch Stuck in Up Position DTC B2207 RR Window Switch Stuck in Down Position DTC B2212 RF Switch on LF Door Stuck Up Position DTC B2213 RF Switch on LF Door Stuck Down Position DTC B2214 LR Switch on LF Door Stuck Up Position DTC B2215 LR Switch on LF Door Stuck Down Position DTC B2216 RR Switch on LF Door Stuck Up Position DTC B2217 RR Switch on LF Door Stuck Down Position DTC B2220 LF Door Lock/Unlock Switch Stuck in Lock DTC B2221 LF Door Lock/Unlock Switch Stuck UnLock DTC B2222 RF Door Lock/Unlock Switch Stuck in Lock DTC B2223 RF Door Lock/Unlock Switch Stuck UnLock DTC B2224 LR Door Lock/Unlock Switch Stuck in Lock DTC B2226 RR Door Lock/Unlock Switch Stuck in Lock DTC B2240 Memory 1 Switch Failed DTC B2241 Memory 2 Switch Failed DTC B2242 Memory Exit Switch Failed DTC B2243 Memory Set Switch Failed DTC B2310 Hand Set Failure DTC B2311 TRU Failure DTC B2312 Software Failure DTC B2355 Driver Front Vertical Sensor Malf DTC B2365 Driver Rear Vertical Sensor Malf DTC B2375 Driver Seat Asm Horiz Sensor CKT Malf DTC B2419 Twilight Photocell Circuit Problem DTC B2420 Twilight Delay Pot Failure DTC B2422 Interior Lamp Rheostat Failure DTC B2460 Navigation Antenna Selector Circuit High Current DTC B2461 Navigation ECU Synchronous Signal Error DTC B2462 GPS Signal Error DTC B2463 Navigation CD Player - No Disk DTC B2464 Navigation CD Player - Decoding Error DTC B2465 Navigation CD Player - Data Error DTC B2466 Navigation VICS Memory Error DTC B2468 Navigation Display Head (NDH) Malfunction DTC B2470 Daytime Running Lamps Fault DTC B2471 Interior Lamp Fault DTC B2472 Low Beam Fault DTC B2473 High Beam Fault DTC B2474 Navigation Display Head (NDH) Back Lighting Malfunction DTC B2475 Navigation Display Head (NDH) Auxiliary Input Malfunction DTC B2476 Cellular Phone Select Service Switch Malfunction DTC B2476 Parklamp Fault DTC B2477 Reverse Lamp Relay Shorted to Ground DTC B2478 Reverse Lamp Shorted to Battery DTC B2502 Auto Trans Shift Lock Control Shorted to Ground DTC B2503 Park Gear (Auto Trans Shift Lock Control) Relay Shorted to Batt DTC B2510 Steering Wheel Controls HVAC Key Stuck DTC B2511 Steering Wheel Controls Conv Key Stuck DTC B2512 Strng Wheel Controls Illegal A/D Values DTC B2515 Strg Whl Cont Illegal Resistance Value DTC B2550 Storage Mode Entered DTC B2556 Interior Lamp Rheostat Circuit Range DTC B2560 RKE Message Validation Error DTC B2641 Delayed Exterior Lighting Ctrl CKT Range DTC B2646 Ambient Light Sensor Circuit Range DTC B2710 PASSKey Open/Shorted Pellet DTC B2711 PASSKey Open/Shorted Pellet After Good Key DTC B2719 CTD-Trunk Tamper Switch Fault DTC B2725 ATC Mode Switch Circuit Malfunction DTC B2734 Coded Key Controller Memory Failure DTC B2750 PASSKey Data Communication Failure DTC B2757 Driver Memory 1 Select Switch CKT Low DTC B2762 Driver Memory 2 Select Switch CKT Low DTC B2767 Memory Set Switch Failed Low DTC B2772 Driver Memory Exit Switch Circuit Low DTC B2780 Wrong Resistor Before Good DTC B2781 Wrong Resistor After Good DTC B2782 PASSKey Pellet Resistance Not Programmed DTC B2783 Key Code/Password Corrupted in Memory DTC B2805 Steering Whl Controls HVAC Sw CKT Malf DTC B2810 Steering Whl Ctrl Entertainment CKT Malf DTC B2853 Telescope Forward Switch Circuit Malfunction DTC B2858 Telescope Rearward Switch Circuit Malfunction DTC B2860 Telescope Position Sensor Range DTC B2862 Telescope Position Sensor Low DTC B2873 Tilt Up Switch Circuit Malfunction DTC B2878 Tilt Down Switch Circuit Malfunction DTC B2880 Tilt Position Sensor Range DTC B2882 Tilt Position Sensor Low DTC B2891 Tilt/Telescope Motor Over Current DTC B2904 Tilt/Telescope 4-way Position Switch Circuit Malfunction DTC B2947 Security System Sensor Power CKT Low DTC B2948 Security System Sensor Power CKT High DTC B2955 Security System Sensor Data CKT Malf DTC B2957 Security System Sensor Data Circuit Low DTC B2958 Security System Sensor Data Circuit High DTC B2960 Sec Sys Sensor Data Incorrect but Valid DTC B3028 Starter Relay Interface Short to Ground DTC B3029 Starter Relay Interface Open/Short to B+ DTC B3031 Key Decoder Device in Assem Learn Mode DTC B3033 Security System Indicates Tamper DTC B3055 Key Not Present DTC B3069 RF/LF Door Key Unlock Circuit Low DTC B3108 Transmitter Synchronization Failure DTC B3142 LF Unlock Switch Circuit Low DTC B3147 Passenger Unlock Switch Circuit Low DTC B3152 LF Lock Switch Circuit Low DTC B3157 Passenger Lock Switch Circuit Low DTC B3172 Window Up Switch Circuit Low DTC B3177 Window Down Switch Circuit Low DTC B3203 Rear Window Lockout Switch Input Circuit High DTC B3282 Window Switch-Express Input Shorted to Ground DTC B3287 LR Window Switch Express Down Circuit Low DTC B3292 RR Window Switch Express Down Circuit Low DTC B3282 Window Switch-Express Input Shorted to Ground DTC B3377 LF Window Up Switch Circuit Low DTC B3382 LF Window Down Switch Circuit Low DTC B3387 RF Window Up Switch Circuit Low DTC B3392 RF Window Down Switch Circuit Low DTC B3397 LR Window Up Switch Circuit Low DTC B3452 LR Window Down Switch Circuit Low DTC B3457 RR Window Up Switch Circuit Low DTC B3462 RR Window Down Switch Circuit Low DTC B3467 LF Window Express Down Circuit Low DTC B3472 RF Window Express Down Circuit Low DTC B3477 LR Window Express Down Circuit Low DTC B3482 RR Window Express Down Circuit Low DTC B3517 LR Door Sw Express Up/Down Window Contact Shorted to GND DTC B3522 RR Door Sw Express Up/Down Window Contact Shorted to GND DTC B3527 Window Lockout Switch Circuit Low DTC B3793 Memory Seat Module Over Current
Bookmarks |
OBDII Error Codes... | Dave_Pletcher | Ion Tech | 18 | 06-01-2009 10:11 AM |
Help with OBDII codes | will4384 | S-Series Tech | 2 | 10-02-2006 12:23 PM |
OBDII Network Codes | wolfman | How-To Library | 1 | 11-26-2004 10:17 PM |
OBDII Chassis Codes | wolfman | How-To Library | 0 | 11-26-2004 09:54 PM |
Interpreting OBDII Codes | wolfman | How-To Library | 0 | 11-26-2004 09:38 PM |
