Old 11-26-2004, 09:38 PM   #1
wolfman
wolfman's Avatar
Information Interpreting OBDII Codes
OBDII Codes are broken down into 4 catagories Body, Chassis, Powertrain, and UNetwork codes. OBDII codes can only be retrieved with scantool. SOME codes can also ONLY be retrieved by a scantool equiped with manufacturer specific proprietary software. Codes retrieved will be in a 5 space format {X X X X X} interpret the 5 spaces thusly:
First digit:
B= Body Code
C= Chassis Code
P= Powertrain Code
U= Network Code
Second digit:
0=SAE Standard Code
1= Manufacturer Specific Code
Third digit:
1=Fuel and Air metering
2=Fuel and Air metering (injectors)
3=Ignition system (missfiring)
4=Auxcillary Emission Controls
5=Vehicle Speed & Idle Controls
6=Computer Output Circuit
7=Transmission
8=Transmission
9=Reserved
0=Reserved
Fourth and Fifth digit(s)
00-99=Identifies specific fault
OBDII GM code lists follow this post
wolfman is offline
OBDII Error Codes... Dave_Pletcher Ion Tech 18 06-01-2009 10:11 AM
Help with OBDII codes will4384 S-Series Tech 2 10-02-2006 12:23 PM
OBDII Powertrain Codes wolfman How-To Library 9 05-24-2005 07:28 AM
OBDII Chassis Codes wolfman How-To Library 0 11-26-2004 09:54 PM
OBDII BODY Codes wolfman How-To Library 1 11-26-2004 09:50 PM
