Old 07-24-2004, 07:10 PM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default Burning a Quart of Oil Per 1500 miles: Oil Pan gasket or Rings?
Which would it be, if I lose a solid quart of oil every 1500 miles?
TIMSPEED is offline
Old 07-24-2004, 07:16 PM   #2
wolfman
wolfman's Avatar
Default
Well, you'll never know how much it's actually burning until you fix the leak...
wolfman is offline
Old 07-24-2004, 07:46 PM   #3
amazinghl
Default
How much oil drip do you have under the oil pan, tranny?
It's relatively easy to change out the oil pan gasket.
00 Insight 72mpg
amazinghl is offline
Old 07-24-2004, 08:31 PM   #4
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Default
Well, I don't know if I have a drip under the oil pan or not. I know that the Oil Pan DOES have oil all over it...but I'm a messy guy when I change the oil/add oil. I'm going to wipe it down good when it cools off, and also put some cardboard under the oil pan to see if it's dripping.
I know it's relatively easy to change the oil pan seal, but if it's uneeded work, it's uneeded work.
TIMSPEED is offline
Old 07-24-2004, 09:06 PM   #5
coliphage
coliphage is on a distinguished road
Default
Put a cardboard under oilpan and let it sit overnight.
You will see something if it leaks.
coliphage is offline
So I checked my oil level after 1500 miles Gnfanatic S-Series General 28 10-12-2008 08:33 PM
Losing Oil? 1 quart every 75 miles cleazenby S-Series General 16 08-23-2008 04:57 PM
oil all down the back of my engine. losing 1 quart every 400 miles or so ASE_Tek0312 S-Series General 31 09-03-2006 12:26 AM
Oil Pan Gasket. ym42 S-Series Tech 6 01-22-2005 12:41 AM
Oil Pan Gasket jasonpopnc S-Series Tech 9 07-23-2004 01:48 AM
