Old 07-13-2009, 02:15 PM   #1
SUPERCHARGE
SUPERCHARGE is on a distinguished road
SUPERCHARGE's Avatar
1993 SL2
Default Cahnging oil pan, where can I get new pan bolts?
Hey peeps, changing the oil pan in my Saturn as it's rusted through, but after taking it off I'm noticing that many of the bolts no longer seem to be reliable enough to last a long time without stripping next time they have to be used.
Do the bolts usually come with a new oil pan? If not, where can I get some new ones? And ugh... how much am i looking at? 5$ a bolt?
Thanks!
SUPERCHARGE is offline   Reply With Quote
Old 07-13-2009, 02:44 PM   #2
Default Re: Cahnging oil pan, where can I get new pan bolts?
I'd be surprised if they weren't standard M6x1.0 bolts. But since they're steel, going into aluminum, you're more likely to strip the threads on the block than on the bolts. If you're worried about ROUNDING (not stripping) the heads, use a 6-point socket.
Old 07-13-2009, 02:49 PM   #3
SUPERCHARGE
1993 SL2
My bad, I did mean round off the heads. The problem is that they're very rusty. Although they may work now, I fear for later. Would finding regular stainless steel bolts be advisable or would they be too weak for even the low torque specs.
Old 07-13-2009, 04:04 PM   #4
ported 95 sohc
ported 95 sohc is on a distinguished road
1995 SL
I'd use stainless on mine if i had to and anti-sezie
that's balla-rific!
ported 95 sohc is offline   Reply With Quote
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
need metric size of oil pan bolts for 97 sc2!! help, wife tossed them out!! travman514 S-Series Tech 3 09-11-2006 10:32 AM
Oil Pan 357kevin S-Series General 11 05-23-2006 08:49 PM
Reaching Oil Pan Bolts 92 Sl1 johnt671 S-Series General 1 04-30-2006 04:20 PM
2003 AWDV6 fluid seepage at tranny pan & oil pan mysaturnvue2 Vue Tech 9 02-16-2005 08:10 AM
