Old 03-31-2012, 01:29 PM   #1
tamancam
tamancam is on a distinguished road
Dizzy 2006 vue high beams come on randomly, drain battery?
A couple of days ago, every time I use my turn signals, the high beams come on. I've found that if I put the switch "just so", the high beams go off and all seems well. Apparently, the high beams also come on randomly on their own, which has caused total battery drain 2 nights in a row now. I spoke with our mechanic, and it will cost !160 total to replace the switch, if that is what it is.
My question, at this point, is, if I completely take out the high beam bulbs, will it still drain the battery? Just for a short fix as our mechanic doesn't have anyone who can fix it right now and I honestly don't have anyone here who is patient enough to fix it on our own
Desperately need help, any suggestions will be very appreciated. We have no use for high beams here, I drive very little at night or in the country, but depend on this car for work and such.
Add to tamancam's Reputation
Rate the quality of this post and help tamancam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tamancam is offline   Reply With Quote
Old 03-31-2012, 01:57 PM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: 2006 vue high beams come on randomly, drain battery?
Provided it is your switch, you can get a new switch for under $40 online (rockauto.com). From what I've seen, they're pretty easy to replace yourself. The steering column cover pops off, and the rest is pretty obvious from there. Surely someone can take 10 minutes to do it.
It would take less time to replace it yourself than it would take you to drive it to your "mechanic" for him to do it.
If you're not willing to take a few minutes to do it yourself, and can't wait for your over-priced mechanic, I'm not really sure what you're asking for with your post, other than confirmation that the switch could be the problem. In which case, I can't say for sure, but it does sound likely.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 03-31-2012, 01:59 PM   #3
tamancam
Thank you, and I've read about that, and it seems fairly easy. Just wondering about the bulbs themselves at this point and if I take them out will it stop the battery drain, or will the battery still be pulled because the car thinks the lights are on?
Old 03-31-2012, 02:06 PM   #4
RedGeminiPA
2004 VUE 3.5L
You could pull the fuse overnight to see if that solves the drain issue. It would be easier than taking the bulbs out.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 03-31-2012, 02:11 PM   #5
tamancam
Thank you Will try it tonight and see how long it will take to get the actual part
Old 03-31-2012, 02:18 PM   #6
far2grumpy
far2grumpy's Avatar
There's no path for current if bulbs are removed.
I suggest you promptly try to obtain a new switch. Its just possible the low-beam section of switch could fail next.
You could remove the two headlamp fuses in the underhood relay/fuse box but keep in mind this will also disable the low-beams.
When you buy the new switch make sure you know whether you have auto headlamp (AHL) option or not as with or without dictate different switches.
And if you're not sure about the AHL check for a small black bulb thingy on dash above and to right of glove-box. The bulb means you have AHL.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Low beams on with high beams mod aaron7 S-Series Mods 12 07-10-2009 12:06 PM
High beams work low beams don't NateM137 S-Series Tech 5 09-01-2008 05:10 PM
2006 Ion clock/radio display randomly shutting off mj3783 Ion General 2 06-04-2008 11:51 AM
Battery Brain: product to prevent battery drain davesaturn Ion Tech 19 04-13-2008 08:19 PM
Battery/Alternator light blinking randomly VinceP S-Series Tech 3 09-12-2004 09:35 PM
