Old 06-23-2008, 12:45 PM   #1
geedavey
geedavey is on a distinguished road
Dizzy 2006 Vue 2.2L oil pan drain bolt torque specification?
What is the oil pan drain bolt torque specification for the 2006 Vue with 2.2L motor? I've looked everywhere and can't find a number.
Add to geedavey's Reputation
Rate the quality of this post and help geedavey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geedavey is offline   Reply With Quote
Old 06-23-2008, 01:12 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: 2006 Vue 2.2L oil pan drain bolt torque specification?
Don't know. I've changed the oil on several different cars multiple times and have never once used my torque wrench to tighten the drain plug. I get it snug and then give it a little extra to tighten it up. With my VUE, I do all of this with the VUE on all 4 tires and not jacked up at all- so my available leverage for over-tightening the bolt just isn't there.
Get it tight, but don't get it super tight. If you're using a rachet, get it about as tight as you can with your hand about mid-way down the handle at most without exerting any extrahuman strength- this will limit your available leverage by using this "shorter" rachet.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 06-23-2008, 01:23 PM   #3
geedavey
Thanks, Tom, that's the only advice I've gotten so far...but I'm anal, I guess, and I'm sure there's a real factory spec number for this torque. Anyone know what it is?
Old 06-23-2008, 01:44 PM   #4
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I can look in my Factory Service Manual tonight if you'd like.
Not a Saturn.
Old 06-23-2008, 01:46 PM   #5
geedavey
Tom, that'd be awesome. Thanks in advance, yes, please do!
Old 06-23-2008, 08:55 PM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Both the drain plug and the oil filter cap are to be tightened to 25 N*m (18 ft*lb).
I tried to scan it but the book is so thick and this section is right in the middle and I couldn't get that part of the page to lay very flat. But see the attachment.
If you need anything else, I can see what I can do.
Not a Saturn.
Old 06-23-2008, 10:42 PM   #7
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Get a Fumoto valve and never have to remove a drain plug again...
Add to BobbyP's Reputation
Oil pan drain plug dogwood2002 L-Series Tech 2 08-30-2009 06:15 PM
Replace oil pan drain bolt or not? Frankd1 S-Series Tech 12 12-05-2008 10:04 PM
2006 Vue V6 AWD... Do I need an oil drain plug GASKET? molinee Vue Tech 12 06-05-2008 08:01 AM
how to remove oil drain pan? Zeroherokid S-Series Tech 8 10-03-2007 12:48 PM
advise on oil....ls2's oil drain pan valve juliansdad L-Series General 6 07-31-2003 10:42 PM
