Closed Thread
Old 01-24-2005, 07:07 PM   #1
Lukexzx
Lukexzx is on a distinguished road
Default Lubrication of automatic seatbelts
Does anyone have the proper method to do this or what type of grease to use? Would lithium grease work?
Luke
94 Saturn SL2
Add to Lukexzx's Reputation
Rate the quality of this post and help Lukexzx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lukexzx is offline
Old 01-24-2005, 07:11 PM   #2
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default Re: Lubrication of automatic seatbelts
hehehe... power seatbelts... pull the fuse... that's what I ended up doing.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline
Old 01-24-2005, 08:14 PM   #3
NavyCPO
NavyCPO is on a distinguished road
NavyCPO's Avatar
1993 SL2
Lithium Grease will work just fine. Once you apply it, cycle the belt in the track a few times.
Jim Hunter, Chief Petty Officer, USN, Retired
93 Saturn SL2 Automatic
Add to NavyCPO's Reputation
Rate the quality of this post and help NavyCPO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NavyCPO is offline
Old 01-25-2005, 05:35 PM   #4
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
I aswell, but I'm considering making them functional again. Gotta be an easy way...
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline
Old 01-25-2005, 11:04 PM   #5
wolfman
wolfman's Avatar
Not to rain on your parade, but if the motorized belts are already not functional, odds are just lubricating them won't be enough to get them working again. (But don't let that keep you from trying anyway...you might luck out)
Add to wolfman's Reputation
wolfman is offline
Old 01-27-2005, 01:30 AM   #6
Lukexzx
Well in my case the seat belts are functional, they just run slow when its cold out. I hadn't been to the dealer in a while, and I noticed some of the visible portion of the track was worn away, looked almost copper underneath. So I took some lithium grease and a small nail and just applied it to the track. This seemed to help, but it hasn't been below zero yet.
I was wasn't sure if I needed to try and get inside the track, which I don't know how to do other and attempting to work it in the crack at one end and hope the cycleing of the belt will apply it internally.
Lukexzx is offline
Old 01-27-2005, 05:19 AM   #7
wolfman
wolfman's Avatar
The "copper" you are seeing may very well be anti-seize compound put there as a track lube by some previous owner. That stuff WILL thicken when it gets cold. You may want to use a bunched up washcloth and a GLOVED HAND (the track edges can be SHARP) to wipe clean the tracks and then relube with white lithium grease. "Spray cable and chain lube" (Wal-Mart or any autoparts store) likewise will work very well and is easy to apply.
wolfman is offline
Closed Thread
take out the automatic seatbelts, is it possible? KawaiiBoricua S-Series Tech 2 03-31-2008 10:10 PM
Last Year for Automatic Seatbelts? fishbulb S-Series General 9 05-09-2004 07:07 PM
automatic seatbelts sebc S-Series Tech 4 10-27-2003 11:00 PM
Are the automatic seatbelts still around? WhtCastle General Saturn Discussion 13 03-17-2003 11:09 AM
Automatic Seatbelts OllieSC S-Series Mods 2 08-16-2002 01:26 AM
