Old 01-31-2019, 01:58 PM   #1
Smokey
Smokey will become famous soon enough
Default Spark Plug Change
Does anyone have detailed instructions on how to change the spark plugs on the 3.6L engine?
Smokey is offline   Reply With Quote
Old 01-31-2019, 06:04 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Spark Plug Change
I don't have a 3.6 and never helped anyone change 3.6 plugs but will attach a few FSM extracts for you to review.
I also have ignition coil removal extracts which are too large to attach to post but I will email if you PM address.
Old 02-01-2019, 07:50 AM   #3
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
On behalf of all of us with 3.6L engine, thank you for posting the how to far2grumpy. Much appreciated.
My '09 Vue with that motor has low miles for its age. I am retired now and don't drive much. Anybody know that the spark plug change interval is on the 3.6L?...miles recommended?
Any horror stories if plugs left in too long that they will bond to the cylinder thread? Anybody know if they use anti seize paste on spark plug threads from the factory?...or if anti seize paste is recommended for spark plug replacement?
Thank you.
gm7 is offline   Reply With Quote
Old 02-01-2019, 11:39 AM   #4
Smokey
Thank you.
I believe they are supposed to be changed at 100,000 miles.The three plugs towards the front look fairly simple, not sure how to access the three in the back.
Thank you as well far2grumpy!
Old 02-01-2019, 03:49 PM   #5
.....Any horror stories if plugs left in too long that they will bond to the cylinder thread? Anybody know if they use anti seize paste on spark plug threads from the factory?...or if anti seize paste is recommended for spark plug replacement?
Some background history of engines and spark plugs may help. Google for info and any changes if I'm mistaken.
Iron engine blocks with cast iron cylinder heads used black oxide coated spark plugs with or without antiseize compound. Black oxide is a surface treatment but oxidation still occurs. Aluminium cylinder heads being softer and easier to strip spark plug holes use longer threaded holes and longer threaded spark plugs. No black oxide, nickel plating on spark plug threads. Aluminum and steel react to each other, described as galvanic action. The result is what I describe as the equivalent of mechanical corrosion creating loctite as the two corroded metals form a tight bond. Nickel plated spark plugs acts as the barrier between the two metals. Some manuals mention using anti seize. Other manuals do not. To further the pros and cons of using anti seize when plugs are already plated, many may remove spark plugs on aluminum cylinder heads and use a wire brush to clean off dirt on plug threads. GM service bulletins stress not cleaning this way as plating comes off and the benefits of plating is lost to prevent metal to metal reaction. Using anti seize lowers friction as plugs are tightened and inadvertently increase torque against soft aluminium threads. This may lead to thread stripping. It's always recommended to use service manuals for guidance as this can be a mine field of choices with inadvertent results. To put it mildly, aluminum cylinder heads are just more delicate than we think.
'05 Vues with 3.5 engines - service manuals stipulate in bold red lettering no anti seize as this can lead to over torquing and damage to cylinder heads. And to remove plugs from a cold engine. Removing plugs from a hot engine may cause cylinder head damage, thread stripping.
My '03 3.0L L300 with aluminum cylinder heads. The plugs were hard to break loose when I replaced them at 100k miles. No anti seize on factory plugs. New plugs went in without anti seize and a torque wrench. I had to remove three plugs recently for compression testing. They came out easily. A faulty ignition coil pack was the culprit.
Old 02-02-2019, 04:49 PM   #6
atikovi
I put that **** on everything.
Old 02-02-2019, 07:45 PM   #7
gm7
gm7's Avatar
2009 VUE Red Line
Great comments pro and con on using anti seize. Yes...slippery slope forgive the pun on how torque can be affected with anti-seize giving false reading on torque value and possible contribution to stripping. Careful when it comes to spark plugs in aluminum heads is of course the best course.
Specific to the '3.6L' Vue, anybody have a manual to see if anti-seize is spec'ed or not for pro and con reasons discussed?
Thanks for the good conversation...an important one.
Old 05-13-2020, 03:36 PM   #8
Mgsystmz
Mgsystmz is a jewel in the roughMgsystmz is a jewel in the roughMgsystmz is a jewel in the rough
Mgsystmz's Avatar
2009 VUE 3.6L
Thank you far2grumpy for the attached files.
However,does anyone know the correct firing order/spark plug order??
Many thanks in advance.
Mgsystmz is offline   Reply With Quote
Old 05-13-2020, 04:26 PM   #9
Mgsystmz
Mgsystmz's Avatar
2009 VUE 3.6L
2009 vue. 3.6
Firing Order 1/2/3/4/5/6
I believe the spark plug order is (Back)1/3/5 and (front)/2/4/6.
Looking for confirmation.
Spark plug change 02saturn77 S-Series Tech 17 10-15-2014 12:24 AM
25k spark plug change Yinzer Astra Tech 0 03-12-2014 01:33 PM
02 Vue V6 Spark Plug Change How To? Andyec Vue Tech 11 03-27-2012 09:21 PM
Spark plug change on an 03 Jchulski19 Vue Tech 15 11-25-2011 01:39 PM
Spark Plug Change beensmoked L-Series General 8 05-19-2011 02:06 AM
