Old 04-30-2007, 07:17 PM   #1
Titanium48
Titanium48 is on a distinguished road
Default Ignition issues, no SES
What does it take to trigger a misfire code (OBD II, 1997 SL1)?
My car recently started to buck and hesitate when accellerating from below 2500 RPM and the fuel economy dropped by 2 km/L (5 MPG). I checked the ignition system and found worn spark plugs and 3 of 4 coil pack towers were white with oxidation.
Replacing the plugs and wires and cleaning off the coil pack towers solved the hesitation problem and restored normal fuel economy, so I'm assuming I just cured an intermittent misfire problem that never triggered a SES light. There have been posts here about cars throwing misfire codes without accompanying driveability problems while I had the opposite experience. What's up?
Add to Titanium48's Reputation
Rate the quality of this post and help Titanium48 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Titanium48 is offline   Reply With Quote
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
My poor 99 SW2, any suggestions, multiple issues- Ignition, Alignment, and idle Underdogdj S-Series Tech 3 11-29-2009 12:17 AM
SES light, canister purge, drive cycle, ignition module,valve cover gasket, etc. Buckdog L-Series General 4 06-13-2009 01:41 PM
Pls Help: Flashing SES, Rough Idle, Bad Ignition Control Module SSUNBRN Vue Tech 11 04-03-2007 10:21 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
