Old 06-06-2009, 07:08 PM   #1
journeyman615
journeyman615 is on a distinguished road
Default High Idle Speed 2002 SL1
I have a 2002 SL1 with automatic transmission that when in park idles at around 1800-2000 RPM's and at a stop light idles high at around 1100 RPM's with the ole foot holding on the brake. There are no trouble codes and I have taken off the idle air control valve and cleaned it. Still had same problem. Went and got another used IAC valve and still have the problem just not as frequently. It kicks in after about 1/2 hour of driving and then when I turn off the car it goes away for about 1/2 hour. Any help?
As a side note, I just recently did have a DTC for low coolant temp and replaced the sensor. Came right back and just replaced the thermostat and it seemed to do the trick.
Add to journeyman615's Reputation
Rate the quality of this post and help journeyman615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
journeyman615 is offline   Reply With Quote
Old 06-06-2009, 08:04 PM   #2
Default Re: High Idle Speed 2002 SL1
Most common high-idle on a gen-3 SOHC is an intake manifold gasket leak (constitutes a vacuum leak). It's "congenital" - many were built with a wrinkle in the gasket. Test - start engine and run/drive until idle races. With idle racing, spray brake cleaner (almost anything will do, but brake cleaner is clean stuff) along the mating edge between the intake manifold and cylinder head, esp. around the #1 runner. If the idle changes, that indicates the engine is sucking in the spray, indicating a leak.
Add to madpogue's Reputation
Old 06-06-2009, 08:25 PM   #3
journeyman615
Thanks a ton! I will try that and if it doesnt work move onto something else. Appreciate the quick response.
Old 06-06-2009, 09:47 PM   #4
TunasTwins
TunasTwins is on a distinguished road
I still think you have an IAC issue. Does it change when you turn the AC on and off? Sometimes doing this has made my IAC stop sticking.
Add to TunasTwins's Reputation
Rate the quality of this post and help TunasTwins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TunasTwins is offline   Reply With Quote
Old 06-06-2009, 11:58 PM   #5
rc1488
rc1488's Avatar
Unlikely. Especially after having replace the original one.
+1 Bad intake manifold gasket.
My how to: http://www.saturnfans.com/forums/sho...d.php?t=115925
Add to rc1488's Reputation
Old 06-07-2009, 09:04 AM   #6
+1^^^^Intake gasket leak.
Old 06-07-2009, 09:07 PM   #7
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Mine was on the bottom of the gasket right by the powersteering pump. I used starting fluid and the engine raced when I found the gap. The How-to above is spot-on.
Some light reading:
http://www.saturnfans.com/forums/sho...lve%2Fdiagnose
Everything that is listed that can happen to a 3rd gen SOHC happened to mine, one at a time. I'd make an afternoon of it and clean you throttle body while you are at it.
Good luck.
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 10-19-2014, 12:28 PM   #8
apillon
apillon is on a distinguished road
2002 SL1
That's it!!
Add to apillon's Reputation
Rate the quality of this post and help apillon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
apillon is offline   Reply With Quote
Old 10-20-2014, 08:33 AM   #9
SL19302
SL19302's Avatar
2002 SL1
When replacing the intake gasket make sure you get all old gasket material off the head and intake manifold, After all the old gasket is removed wipe he area down with acetone to remove oil and dirt so the new gasket will make a good seal and repair the leak.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 10-20-2014, 02:20 PM   #10
Cruzer32
Cruzer32 has a spectacular aura aboutCruzer32 has a spectacular aura about
Yup, same issue mine had after changing the intake gasket.
In the summer months when the AC is continually on/off, no problem. The issue comes back in the winter months.
I'm thinking it's IAC related, but it only happens when it's too damn cold to work on it!
Add to Cruzer32's Reputation
Rate the quality of this post and help Cruzer32 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cruzer32 is offline   Reply With Quote
High Idle Speed LEWIS4246 S-Series Tech 3 03-08-2007 05:31 PM
High Idle on 2.2l 5 speed Vue pdough Vue General 6 12-20-2006 11:05 AM
high idle speed mystery bfitz S-Series Tech 9 04-02-2005 10:50 AM
misfires at idle, high idle speed mysaturnsucks S-Series Tech 9 01-27-2005 09:27 PM
high idle speed rocknrt Miscellaneous Tech 1 07-17-2002 09:08 PM
