Old 11-17-2005, 11:06 AM   #1
johnbasler
johnbasler is on a distinguished road
Default Anyone have coolant leaks? Water pump? '03 3.0 V6 FWD
Guys/gals,
after resolving my oil leaks by replacing both valve cover gaskets, now I am confronted by a sporadic DexCool puddle under the Vue when parked. ('03 V6 FWD). It seems to occasionally puke a bit of coolant after shutoff, but not every time.
I looked underneath and it likely looks to be coming from the front of the engine somewhere but it could be virtually anywhere....
anyone have coolant leaks on the 3.0 motor? I know it could be anything from a water pump to a hose or anything, but just looking for ideas. Has anyone needed a water pump or anything related?
I really hate to dump stopleak in there, but I really don't want to have to disassemble the front of the engine to look for the leak.
Any advice appreciated!
thanks...
Add to johnbasler's Reputation
Rate the quality of this post and help johnbasler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnbasler is offline   Reply With Quote
Old 11-17-2005, 12:09 PM   #2
scotted73
scotted73 is on a distinguished road
scotted73's Avatar
2007 Outlook XR
2002 L-Series 3.0L Wagon
Default Re: Anyone have coolant leaks? Water pump? '03 3.0 V6 FWD
I just had the water pump on my '03 AWD V6 replaced under warranty (5 yr/60,000). I have about 56,000 miles and also noticed the sporadic drops on my garage floor. First it began with the familiar coolant smell and then the occasional drops. Sounds as if you have the same problem. The service department also replaced the belt tensioner under warranty. I would recommend they check that also and the belt while replacing the pump.
Add to scotted73's Reputation
Rate the quality of this post and help scotted73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scotted73 is offline   Reply With Quote
Old 11-17-2005, 02:37 PM   #3
johnbasler
ok, thanks for the heads-up.
will investigate further. I will be doing the repair myself, so hopefully it is not a horrible job...
Old 11-18-2005, 12:20 AM   #4
The water pump is the big leak source on the front of the 3.0. That said the thermostat and oil cooler cover can seep enough down the front to fool you. best way to find out for sure is to get the timing belt cover off to see if the pump is actually leaking. If the coolant at the front of the engine is wetter than dry the chance is that most of the coolant is from the water pump.
Add to ssicarman's Reputation
Old 11-20-2005, 04:34 PM   #5
johnbasler
thanks!
will get cracking on replacing it.
Old 11-28-2005, 01:49 PM   #6
PortugalFocus
PortugalFocus's Avatar
There is a cooler plate that crosses between the heads to keep them cool. There is a TSB out for coolerplate failures on the 3.0 VUE and the L. Take it to Saturn if they would fix it for you at no charge, before you throw parts at it.
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2005, 10:24 PM   #7
Saturn will only repair for free if the car is still under warrenty.
Classic water pump coolant leak? cfg83 S-Series General 25 11-30-2011 07:42 PM
Leaking coolant, I think it's the water pump Seņor Ramos S-Series General 21 09-03-2009 06:01 PM
Coolant leak from water pump jonnycube S-Series General 36 08-17-2009 07:37 PM
Help ? on water pump and coolant rlhdghhmh S-Series Tech 6 11-18-2006 03:24 PM
Water pump/timing belt on 03 VUE FWD V6 johnbasler Vue Tech 5 01-10-2006 11:35 AM
