Old 10-30-2019, 03:41 PM   #1
RCRV
RCRV is on a distinguished road
Default 2008 2.4l error code po1016 Cam/crank sensor or timing chain?
2008 vue 2.4l engine, 115,000 miles. Started to have horrible acceleration and within 5 miles was running poorly. Now is very hard to start but when it did it ran with no unusual noises.
Code shows poo16 po455 and po326. p0016 is cam crank sensor but I see on the net it could be a timing chain problem. po455 is large emision system leak. po326 is knock sensor.
May I safely assume I'd better take off the valve cover and check the chain first before checking/changing cam and crank sensors and then trying to start it? Just in case the chain is loose I don't want it to skip and have a valve piston collision.
If I have to replace the chain how big a job is that? I am skilled enough to do it, just wandering how tough it is to do with the engine in the car.
Any other advice will be appreciated.
Add to RCRV's Reputation
Rate the quality of this post and help RCRV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RCRV is offline   Reply With Quote
timing chain do pull chain after I turn crank 3 oclock Packard S-Series Tech 2 08-15-2016 09:51 AM
Saturn Vue 2008 Error Code P0341 LastSurvivor 2008 Vue 1 07-29-2016 01:07 PM
2008 Aura XE 3.5 Error Code Issue Tajee Aura General 6 05-19-2015 01:51 PM
2008 Vue 2.4L Thermostat Error Code Really?? Vue Tech 4 01-22-2014 06:03 PM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
