Old 09-29-2019, 09:54 AM   #1
Noman
Noman is on a distinguished road
Default Bearing noise
Hello, I have 2006 Saturn Vue. Iím getting a bearing groan under my feet, I can feel it in the floor both driver side and passenger side and can feel it in the brake pedal. Itís not the typical wheel bearing noise that gets louder going around curves. It starts as soon as the Vue starts moving and gets louder the faster it goes. Is there a way to determine if itís the intermediate shaft bear or the bearing at the ends of the differential? I think this is like a typical differential that has axel shaft bearings at the end of the differential. The noise has gotten a lot louder over the last couple weeks
Add to Noman's Reputation
Rate the quality of this post and help Noman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Noman is offline   Reply With Quote
Old 09-29-2019, 01:07 PM   #2
Noman
Default Re: Bearing noise
I raised all four corners and put it I. Gear to listen and the sound is coming from the drivers side. Canít tell if itís the wheel bearing though.
Old 09-29-2019, 04:34 PM   #3
waiter21
2003 VUE 2.2L
Wheel bearings, change both sides.
Add to waiter21's Reputation
Old 09-29-2019, 05:20 PM   #4
Noman
Keeps throwing me for a loop. Iíve had front bearing go bad and it get louder when going around curves. And this doesnít do that.
Old 10-04-2019, 06:28 PM   #5
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
I had the same thing happen on my Aura. It was both front wheels making noise. I'm very familiar with the sound of bad wheel bearings, so I just went ahead and bought new bearings, and sure enough it fixed the noise problem.
But like you, it had me really scratching my head on why it didn't get louder on corners.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 10-05-2019, 09:59 PM   #6
Noman
Looks like Iíll be changing wheel bearings. Thanks for the help.
Old 10-06-2019, 03:02 PM   #7
Cavell
Like this? At least vikes are winning
File Type: jpg 67B8737D-7E20-46AA-8454-5C897C5B8451.jpg (152.7 KB, 18 views)
Add to Cavell's Reputation
Old 10-13-2019, 10:56 AM   #8
Noman
Iíve never changed wheel bearings without removing the cv shaft
Old 10-24-2019, 06:16 PM   #9
Bismarck318
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
Sounds dangerous, but if you have access to the correct facilities......
Only $861 on my last go around
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-01-2019, 10:26 AM   #10
Northerner
Northerner is on a distinguished road
2004 VUE 2.2L
Vikes fan here.
Is there a simple way to determine whether or not my rear brakes are ABS or not, before I buy some wheel bearings off Rock Auto?
I'm sure they are ABS, but the last thing I want to do is order the "w/ABS" wheel bearings only for my mechanic to have the truck up in the middle of a job and find they are in fact not ABS.
Mine is a 2.2L, with manual stick shift. I do have power windows (indication it's a little bit better of a model??)
Add to Northerner's Reputation
Rate the quality of this post and help Northerner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Northerner is offline   Reply With Quote
Old 11-01-2019, 12:23 PM   #11
carlito
carlito is on a distinguished road
carlito's Avatar
2004 VUE Red Line
Look for the sensor wires and mounting bracket
Add to carlito's Reputation
Rate the quality of this post and help carlito reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carlito is offline   Reply With Quote
Help please, bearing noise...but not bearing problem at all!! Satillac S-Series General 18 09-01-2013 03:56 AM
'05 VUE Hub/bearing noise caveeagle Vue Tech 7 06-13-2012 04:09 PM
Bearing noise spruce74 L-Series Tech 0 10-08-2005 07:30 PM
bearing noise,I think dcp S-Series General 0 09-19-2005 05:19 PM
Tire and or Bearing Noise Maritime Storm Ion General 7 06-06-2004 08:36 PM
