#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
I've had my engine and transmission out for rebuild. It seems like it would be a matter of removing the automatic, putting in a manual, and then adding the clutch pedal and stuff. Plus you would want to swap in a manual ECU, though I think people have kept their ECU and done the swap.
You can search for some threads as others have done this on the forum, or perhaps they will speak up.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#22 |
![]() ![]() Join Date: Sep 2011
2000 SL1
https://stlouis.craigslist.org/cto/d...261713570.html
He lowered the price from 2,000 to 1,800 I should be jumping on it I think. Someone talk sense into me one way or the other. 😂 |
#23 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
They are getting harder to find, and the decent ones are more expensive. Essentially you are paying for the cleanliness. Mechanical work can all be replaced, but interior, exterior, and frame pieces are hard to find new ones of.
1994 Sl2 5spd First Car, Stock: 56,576 (Totaled 1/10/2018) 1995 Sl2 5spd: Retired Daily, Not Stock: 192,000 1998 Sl2 5spd: Family Car, Stock :135,000 1995 SW2 4spd: Daily, Stock: 91,000 |
#24 |
2000 SL1
Very true I'm seriously thinking about the wagon I posted above if it was a stick id be buying it right now .
#25 |
![]() Join Date: Mar 2015
1997 SC2
1999 SC2
HA! I physically drove that white one actually... thought it was going to be nice and I wanted it to be nice... but I had to pass. The ironic problem with these cars, is that they can look so good on the outside.
One thing that caught my eye was that the sway bar broke off the frame... so the bracket was welded on half-hazardly. |
#26 | |
2000 SL1
No kidding? When did you drive it? It does look good in pictures . Was that the only thing wrong with it? Or where there other issues? |
#27 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015
My garage is 75 feet from the house....
Currently owned 93 SC2 96 SC2 97 SL2 98 SL2 99 SC2 01 SC2 x 2 yellow 02 SC2 02 SL2 auto 02 SL2 5 sp parts 2 94 SC2 parted out 2 96 SC2 98 SC2 - rusty frame minus engine. |
#28 |
http://www.differentracing.com/tech_...anny_swap.html
Low Saturn did the first auto to manual swap on an S-series, documented at his site. Like Waiex191 said, you can keep the auto PCM. You'll always have a CEL for trans codes, though. Some folks said they can feel a slight flat spot when accelerating that would correspond to when the auto PCM would be shifting gears. The other weird thing is that the auto PCM will not disengage cruise when the RPMs don't match the map. That means you could have a DOCH engine and DOHC auto trans PCM but install an MP2 manual trans from a SOHC car but retain cruise.
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#29 | |
I wonder if you provide some documentation that it might be excluded. If it is an invalid code for the car.
1999 SL2 MANUAL ~78K |
#30 |
![]() ![]() ![]() Join Date: Jun 2016
2003 L-Series 2.2L Sedan
Just so happens I have a '01 SL1 SOHC, 4-door Sedan, AT for sale! Good car and has the RV's tow plate and wiring installed to tow it 4-down. It only has 78,000 miles on it. Asking $2756 because I'm in a town with 22 RV parks so the tow package adds value. And I've pretty much fixed all the standard SL1 issues over the years I've owned it. Even the rippled head gasket has been changed. Oh, and the ECT is the brass one now. Oh, and the tranni has the main valve coil changed. And on and on.
I'm over here in the desert of the west near Las Vegas and the local junk yard had 5-7 Saturn's in various condition last I checked. It was interesting when I found them all as I'd been looking all over the country, even in Iowa, at various junk yards and usually I'd only see 1-2 Saturn's, if any. Strange that I ran into so many here 55 miles west of LV. Speaking of Iowa though, I was in one junk yard in Fairfield and though they didn't have any Saturns, they had ~100 ECMs for them. Strange huh?
2003 Saturn L200 DOHC, 2.2L Luxury Transport 66,000 miles Jan. '21 2001 Saturn SL1 SOHC, 1.9L Basic Transport 78,000 miles Jan. '21 Last edited by Jim@HiTek; 01-21-2021 at 09:26 PM. |
#31 | |
1997 SC2
1999 SC2
#32 |
2000 SL1
Yeah says a lot. Very sad! Ugh.
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
Here you go Dakota, low miles, 1997 SW2, but automatic.
https://www.sovereignauto.com/vehicl...02b4edbccb37db |
#34 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009
Here’s one for $2k, the price is outrageous. The car looks like it was in a police pursuit, hit multiple things/people, and just got out of impound. This is a $500 car.
https://www.ebay.com/itm/2000-Saturn...1/293981343155 |
#35 | |
1995 SW2
#36 |
This is a $500 car.
#37 |
2000 SL1
![]() Looks good for $500!! https://www.facebook.com/marketplace...9135720130255/ I'm looking at this tomorrow. Apparently the radiator appears to be leaking all the pictures and videos look good no door sills rust interior was decently clean. Radiator is seeping at the top other than that they said they don't believe there is any issues. Anyone have thoughts or opinions. |
#38 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
Nice looking car. No small car being sold today is half as attractive in my view. If they were making them new, I'd buy one again. An S-series with a ~200hp turbo and a six speed trans would be a sweet package.
#39 | |
http://www.saturnfans.com/forums/sho...d.php?t=234273 If I do sell the SC2, I'll look for a desert or southern 5sp wagon to rebuild someday. If I don't sell it, I'll rebuild it after I finish my other project, then drive it for another 23 years.
#40 | |
There's a lot of pretty beat up S-Series out there, but even those are in better condition than one that have been long crushed.
97 SL2, auto, 122K miles |
Vue is getting harder to start | stbvue | Vue General | 15 | 11-14-2010 12:56 PM |
Getting harder and harder to start 2002 | lentinman | S-Series Tech | 11 | 10-29-2010 08:51 AM |
Getting harder to start | coolcat2 | S-Series General | 5 | 04-28-2010 12:10 PM |
Harder and Harder to shift into First. | SL2Ghost42 | S-Series Tech | 12 | 10-06-2003 12:39 PM |
ION makes it harder to pump gas | jaysc2 | Ion General | 30 | 04-03-2002 04:03 PM |
