Old 06-15-2020, 03:34 PM   #1
JohnnyMillions
JohnnyMillions is on a distinguished road
Default P700 & P752 error codes, options?
My 2008 Outlook with 86k miles just recently stopped shifting out of first gear and the check engine light appeared. After I reached my destination, and I turned it off, it started shifting again.
Autozone pulled the P0700 & P0752 codes.
It happened one other time.
What are my options to fix this? New tranny?? It is still safe to drive? Thanks!
JohnnyMillions is offline   Reply With Quote
Old 06-16-2020, 08:52 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: P700 & P752 error codes, options?
Some info...Hope it helps...
P0700
https://www.700r4transmissionhq.com/...aturn-outlook/
P0752
https://www.engine-codes.com/p0752_saturn.html
Old 12-03-2020, 11:26 PM   #3
nm1hart
nm1hart is on a distinguished road
No! Only tells me what I already knew.
What we need to know is How to remove and replace the speed transmission 1 gear Solenoid that is stuck open. and what is the location of the 1 gear Solenoid? located at on the transmission. Compared to the other gear Solenoid. I can find pictures of the gear Solenoids. but nowhere does it actually point to which Solenoid is which.
or the procedure to replace it. with location ON THE TRANS!!!
nm1hart is offline   Reply With Quote
Old 12-03-2020, 11:30 PM   #4
imaddicted2u
2008 AURA XE
How the heck is anybody supposed to know what you already knew...
Good luck!
Old 01-11-2021, 09:22 PM   #5
Doug C
Doug C's Avatar
2008 Outlook XE
And is it even the same person (nmhart' dec 2020) posting interest in the topic, started by "johnnymillions" in June 2020 ?
Error codes Jaybone586 S-Series Tech 1 06-05-2014 05:58 PM
Error codes Big Cee Aura General 1 10-02-2012 11:44 AM
Error codes on 94 SL2 kindashort S-Series Tech 25 03-07-2007 12:40 AM
Error codes paxman356 S-Series General 3 10-22-2005 11:49 AM
Error Codes andyr13 S-Series Tech 6 07-30-2005 10:17 AM
