Old 11-16-2020, 12:26 AM   #1
bigblue72
bigblue72 is on a distinguished road
Default Check Gas cap, ABS warning light show up together
I have a 2005 Relay, 115000 mlles that I drive maybe once a week. Has been an awesome vehicle with never any warning lights. Today I drove around doing some errands and van running fine. On my way home I had the "Check Gas cap" message show up. I stopped and retightened the cap. After a few miles down the road the ABS light comes on and the transmission starts shifting hard. Just some noticeably hard bumps when going thru the gears. Van made it home and I parked it. Are all these problems related in some way?? Im thinking a vacuum leak or a bad evap valve. Would a bad evap valve affect the transmission like that. Where should I start on diagnosing this problem. Thanx.
bigblue72 is offline   Reply With Quote
Old 11-21-2020, 10:28 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Check Gas cap, ABS warning light show up together
I wouldn't think so, maybe a wiring problem. Read trouble codes to get some direction to start.
Check Coolant Level warning? houstonray Astra Tech 43 05-08-2016 10:46 PM
Failed Smog Check After Erasing Check Engine Light Code trench619 Ion General 9 05-01-2015 11:58 AM
03 Ion Coolant warning/check engine light. rcote20 Ion General 20 02-25-2013 02:46 AM
turn key to the Run position, the warning light don't show john_lu S-Series Tech 7 11-17-2006 10:02 AM
Please help me ID this warning light! The Punisher S-Series General 6 11-22-2005 03:11 PM
