Old 03-03-2018, 10:59 AM   #21
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Re: 2002 Saturn L200 Ugly Headlights
The drl are on the high beams in the 2000 to 2002 lights.
2002 L200/5 Loaded, over 1/4 million miles!
Old 03-04-2018, 12:23 AM   #22
Thanks for the heads up as I did state may or may not have DRL issues. I'm loathe to review manuals sometimes......... This makes it a simple choice whether to cut open light assemblies to custom fit hid projectors or not. My '03 L300 uses low beams as DRLs..... And since I have projector lights but halogen lamps I simply replaced them with hid lamps and ballasts to have DRLs and low beam hid lights.
Old 03-04-2018, 01:40 PM   #23
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
I did this with our 2002, results were fantastic.
soulsurvives is offline   Reply With Quote
Old 03-04-2018, 02:05 PM   #24
Can you make the picture bigger?!
I can't see anything to suggest your headlight assembly was modified. Did you cut a hole to fit a hid projector assembly where the low beam reflector resided? If yes then kudos for the effort.
Old 03-05-2018, 12:12 PM   #25
soulsurvives
It kills me, on every other forum the pic size is normal and here it's huge. I took the entire headlight apart, I cut off the glare shield and then made the center hole larger. I then installed a Morimoto H1 bixenon projector and put it all back together. It is not easy or quick, but the results were great.
Tags
2002 l200, headlights, older model
2002 Saturn l200 Barnacle14 L-Series General 12 08-19-2013 07:13 AM
2002 Saturn l200 james14 L-Series Tech 1 12-22-2012 04:25 PM
2002 Saturn L200 2.2 162,000 james14 L-Series Tech 1 12-19-2012 01:56 PM
L200 ugly trim strips MikeNW L-Series General 5 02-22-2012 11:38 PM
Where can i go for nice headlights for my 2002 Saturn l200? Phillyrican L-Series General 2 09-03-2009 09:51 PM
