Old 02-04-2016, 09:41 PM   #1
SkyNET97
SkyNET97 is on a distinguished road
Default 1998 SL2 Headlamp Problem
I am attempting to troubleshoot a dead headlamp. a couple weeks ago my mother noticed the driver's side low beam is not working. had my brother do a quick bulb check and the bulb is ok (swapped to passenger side) the daytime lights work fine, as do the high beams, and the low beam pass side. i have a circuit tester i have dug up (dark right now, not leaving tonight so no need to check) my brother suggested the connector that the bulb connects to might be pooched. as far as i can tell all fuses are good it is just the driver's side low beam no longer lights up. any other troubleshooting tips?
SkyNET97 is offline   Reply With Quote
Old 02-05-2016, 12:02 PM   #2
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Default Re: 1998 SL2 Headlamp Problem
Did you test for voltage at the light socket? Check for corrosion in there as well.
lamping.ap is offline   Reply With Quote
Old 02-05-2016, 12:14 PM   #3
SkyNET97
I have not checked for voltage, all i have atm is a circuit tester. and unfortunately i have not checked it yet and checking for corrosion there was none.
(the tester i have only checks if power is getting to the point)
Old 02-05-2016, 08:04 PM   #4
SkyNET97
I have an odd question, is it possible to connect the lead for the bright lights to the normal lights and turn on the high beams with the column but it is only low beam, or is there more power being delivered to the bulbs?
Old 02-06-2016, 02:18 AM   #5
lamping.ap
I wouldn't go hacking away at the electrical system... get a meter and test the socket properly.
Old 02-06-2016, 02:21 AM   #6
SkyNET97
i did not inted to hack away at any wires, i was thinking more of disconnecting the high beam bulbs and connecting them to the low beam bulbs, but keeping them in their current location.
Old 02-06-2016, 08:35 AM   #7
toggenburg
toggenburg's Avatar
The harness plugs are different between low and high beams and are not swappable, you just can't place the high beam plug onto the low beam bulb without modification.
Don't do it, use a multimeter and find out what is wrong with the low beam harness and plug.
Old 02-06-2016, 12:14 PM   #8
SkyNET97
Gotcha, was only curious if that was possible. all i have is a circuit tester, so i will be hitting it with that here shortly.
Old 02-06-2016, 04:07 PM   #9
SkyNET97
Alright, checked with a circuit tester and there does not seem to be a complete circuit at the plug itself. Followed the wires back a bit and found something my brother said was not the problem, it was. a small sliver was cut on the orange wire and the wire itself inside the insulation had separated. stuck my circuit tester in there and it lit up. going to cut the bad section that is only about a centimeter at most, and either splice a small wire in there or just reconnect them.
Old 02-06-2016, 05:08 PM   #10
SkyNET97
Whoo Hoo!! spliced in a small length of wire i pulled from an old computer fan, similar gauge, wrapped it up in electrical tape. Both lights are working again.
Old 02-07-2016, 08:18 PM   #11
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
Great news...BUT you should go back in and solder and heat shrink that connection if you want it to last.
The way I hear those Police down there pulling folks over for non-working headlights, I'd be doing it double quick.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Tags
headlights, sl2
Startup problem 1998 SL2 telperionflower S-Series Tech 2 01-18-2013 12:18 PM
Key Problem - 1998 SL datlas S-Series General 17 10-11-2012 12:23 PM
1995 Saturn SL1 Headlamp problem Baeldeth S-Series Tech 4 09-17-2011 10:08 PM
Headlamp problem p-ROCK S-Series Tech 5 02-28-2009 05:23 PM
1998 SL2 old 341 problem financialguy S-Series General 1 06-14-2005 12:16 AM
