Old 09-27-2014, 11:37 AM   #1
chipsteph12
chipsteph12 is on a distinguished road
Question Headlight/Battery Flicker
Hello,
I have a 2002 Saturn SL, 109,000 miles 5 speed. About two weeks ago I started having a problem. My headlights and dashlights flicker when I get above 2200 or 2300 rpms. Also, the battery light has started coming on at the same time. If you drop to 2000 rpms or below, no problems (battery light goes off, headlights stay on). I've had the battery and alternator checked twice, no problem. Any ideas where I should look next would be greatly appreciated.
chipsteph12 is offline   Reply With Quote
Old 09-27-2014, 12:04 PM   #2
Signmaster
Default Re: Headlight/Battery Flicker
Unless you have a slipping belt, bets are still on the battery or alternator. I'd check with a meter and alter the rev range to see what voltages show. It's possible you have a connection or ground that is intermittent and only showing up at certain rev ranges, but IMO that isn't likely if it consistently relates to RPM.
Battery cables and connections can look good and have issues as well. But for charge to drop as revs rise isn't very common.
Old 09-27-2014, 01:28 PM   #3
billysvue
or maybe V regulator is going/bad diodes and V is spiking?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 10-14-2014, 05:01 AM   #4
RichardM
RichardM is on a distinguished road
1998 SL1
Did you figure out what it is??? I was having a problem last year and decided to re[lace a seven year old battery. Six months later noticing problems coming back... I am going to try replacing the alternator next
RichardM is offline   Reply With Quote
Tags
battery light, flash, flicker, headlights
Intermittent cluster flicker after battery change rijoemi L-Series Tech 3 05-15-2013 04:09 AM
Weak Battery? - Lights flicker RLFEEN S-Series Tech 4 09-26-2010 09:29 PM
DRL indicator flicker bryanb S-Series Tech 2 09-18-2008 11:26 AM
All my lights tend to flicker AtlantaMike S-Series General 3 03-19-2005 01:21 PM
Low Cooland and Low Battery Lights both Flicker at the same time HomeBase S-Series Tech 13 09-05-2003 12:42 PM
