#1 |
![]() Join Date: Mar 2011
Hello all, I have had my 08 Astra XR 5 sp for about a month and I really like it. I bought it with 5,500 miles. However, I have a weird problem with the headlights. Whether in Auto or Manual mode, the headlights will turn off while driving, just to turn back on a few seconds later. I took it to the dealer and they could find nothing. On the way home from the dealer today, it did it about 5 times.
It does it during the day as well as night. The headlights shut off randomly and the dash gets brighter as it should. With or without fog lights on. I have found no pattern and the dealer didn't find any problems.....what can i check? Thanks ![]() |
#2 |
![]() Join Date: Feb 2010
2008 Astra XR
I (sometimes) have a similar problem- at first, I was highly concerned, but concluded it had to do with the sensor for the auto head lights....
#3 |
I thought the same thing as well. But at night on a dark country road, they will go off.....I am afraid that they will just go off and stay of one of these times - of course at the most inopportune moment...
#4 |
![]() Join Date: May 2009
2008 Astra XR
Could just be a loose wire in your headlight switch? Or could be a prob with the main computer module. VCM, CIM or something like that. I had the same problem and had that part replaced and no prob since. Its basically the computer that controls all the electrics in your car. Good luck.
#5 |
It cant be the sensor, since it does it in manual mode as well as auto. But I dont know what it could be.
#6 |
![]() ![]() Join Date: Jul 2003
2008 Astra XR
perhaps the switch is overheating and shutting down, or if the headlights are on a relay, then maybe it is defective.
Gerry 72 Buick GS red 2008 Astra XR black 3dr 99 SL1 |
#7 |
Good point! Perhaps its a loose/corroded ground connection?
VCX NANO |
#8 | |
![]() Join Date: Oct 2008
2008 Astra XR
![]() Quote:
check my posts have the dealer change the module they changed for my issue.... |
#9 | |
2008 Astra XR
![]() Quote:
Here is the part that was relaced and part number CORRECTION: (6C) COMPONENT INOPERATIVE REPLACE VEC AND PROGRAM PARTS----QTY--------FP-NUMBER----------DESCRIPTION-------- -----------1 ---------- 93190849 ----------BLOCK 024830 SP |
#10 |
Thank all of you for your replies/ideas! I will take the part number to the dealer on my next visit. I'll let you know the results.
thanks again ![]() |
#11 |
Thanks to your posts, my dealer has agreed to order the fuse box under warranty.....I'll let you know if it fixes the headlight problem...
#12 |
I had a fellow with an XE stop and ask me about this issue while I was at a local ex-Saturn dealer on unrelated business, and I distinctly remember reading something on the forums pointing towards a defective REC (Rear Electrical Center). It was his third time to the dealer, and of course it wouldn't act up for them. I told the guy what I knew of the matter, and he wanted me to talk to his Service Advisor. But like I said, I was there on business, but told him about the REC and told him where it was located on his car. When I was done about a half hour later, he was gone.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering." |
#13 |
The part number you gave me fixed the problem
![]() Now the daytime running lights work too (i never knew that they weren't working correctly) Thanks again! |
#14 |
2008 Astra XR
No problem, glad I helped..... It took me over 6 months and 4 dealer visits, countless calls to GM headquarters Canada to get the problem fixed.
#15 |
Now I'm feeling bad. The fellow that I mentioned in an earlier post wanted me to talk to his Service Advisor for him, but at the time I thought I had explained what it was in simple enough terms that he could do the talking. Now every time I revisit that dealership, I expect to find him sitting in the customer waiting area still trying to get his problem fixed. It's driving me nuts! I need a drink!
Bookmarks |
Tags |
electrical, headlights, random |
Headlights won't turn off | asia0372 | S-Series Tech | 6 | 03-21-2010 04:57 PM |
Headlights won`t turn off | michael1944 | L-Series Tech | 1 | 05-12-2009 09:51 AM |
Headlights keep going off, and need to tap lens to turn on... | Kristine | S-Series General | 5 | 12-29-2008 11:27 AM |
2001 SL Sedan Randomly stalls and/or won't turn over | smckech1972 | S-Series Tech | 3 | 11-07-2006 11:43 PM |
Headlights won't turn off | cruzr | S-Series General | 10 | 07-11-2006 07:04 PM |
