![]() Join Date: Mar 2017
Hello,
I have a 2006 Saturn Ion 2. Yesterday, my low beams stopped working, but my high beam do. I have checked for blown fuses, and found nothing wrong. I replaced both headlamps, and still have only high beams. The low beams worked fine on the previous evening, with no dimming or flickering. Does anyone have an idea what the problem could be? |
Welcome to SaturnFans, spacer7767!
Presuming you have no wiring problems, there are two other components which could relate to the loss of the low beams functioning: the headlamp relay and the headlamp/turn signal switch. When you turn on the headlamp switch do the parking lights, and/or running lights go on or not?
374K miles - Holy canolli! Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?! |
![]() Join Date: Jan 2017
I am having the same issue and yes when I turn on my lights my parking lights do come on
As I look back on this original message and reconsider it I'm more inclined to believe that there is a faulty headlight switch here. It seems to me that if the relay had failed there would be no headlamps functioning at all.
BTW, do IONs have Daytime Running Lights (DRLs)?
#5 | |
![]() Join Date: Oct 2018
2006 ION-2 Sedan
I am not a mechanic but I am willing to learn. If I honestly believe it is over my head, I'm smart enough to seek one out. |
Tags |
headlights, high beams, low beams out |
2006 vue high beams come on randomly, drain battery? | tamancam | Vue General | 7 | 10-29-2021 11:22 PM |
High Beams indicator flickering, cutting DRLs, but no high beams | andymcconnell | L-Series Tech | 6 | 10-04-2012 10:14 PM |
Low beams on with high beams mod | aaron7 | S-Series Mods | 12 | 07-10-2009 12:06 PM |
High beams work low beams don't | NateM137 | S-Series Tech | 5 | 09-01-2008 05:10 PM |
96 SC2 headlights pop up, hi beams work, lo beams don't | pantero21 | S-Series General | 5 | 05-06-2006 04:46 AM |
