![]() Join Date: Jan 2017
Hey guys,
So I just recently purchased a used 05 Saturn VUE, AWD V6 Base Model and driving it at night was super scary, I cant see more than about 25 feet in front of me, after that the lights just end on the road, they dont gradually fade into the dark like most car lights, they just have a solid end. Light against dark, there isn't a fade. I live in the woods and deer are always jumping out. How do I increase the distance they shine??? My brights work fantastic, and my fog lights are fine. But my normal headlights are terrible. Thanks guys! |
![]() Join Date: Feb 2017
Bad lighting is usually due to that:
-Bad adjustment -Poor quality bulbs -Opaque/yellow-ish lenses -Wrong wiring grade/bad connections -Genuinely bad engineered reflectors They're almost all easy to correct and inspect. I assume the car is fully stock so the wiring grade and the adjustment are probably untouched. Do the most illuminated spot seems well placed on the road? Is it too low or too high? If it looks well adjusted, i would think about the lenses that doesn't let the light come out of the headlights. Are they full translucent or matte and yellow-ish?
1995 manual Saturn SL2 320 000kms 1995 automatic Toyota Tercel 28 000kms 2000 automatic Volvo S70 probably more than 400 000kms |
![]() ![]() ![]() Join Date: Aug 2012
All headlights have adjusting screws. Dig around the lens and you'll find it.
'05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows. |
Remove the low beam lamps for examination. Maybe the previous owner put in lamps; supposedly brighter halogen lamps have a shorter life by burning brighter then dimming as they age, cheap LEDs that don't work to throw a shorter beam, and cheap replacement lamps.
#5 |
![]() Join Date: Oct 2012
2007 VUE 2.2L
You may want to consider auxiliary lighting, too.
1991 SL1 5 sp 120K mi SOLD 2004 Ion 2 L61 5 sp 155K mi SOLD 2005 VUE L61 5 sp 181K mi LOST IN TS JOAQUIN 10/2015 2007 VUE L61 5 sp 155K mi |
2003 VUE 2.2L
I noticed my Vue lights generally aren't very bright as well. This may sound like a silly suggestion and may not be at all related to the problem you're experiencing, but have you considered cleaning up the headlights at all? Forgive me if this has been done but I ended up cleaning off the headlights a couple times and noticed the lights are a lot brighter with less oxidation. The inside still could use a go over but I'm selling my car soon anyways so the new owner can do that if they want. If the headlights have relatively little oxidation please feel free to dismiss my suggestion :-)
Tags |
headlights, help needed, how to increase, shine, short distance |
Headlamps improper for night driving | scarlett | Astra Tech | 36 | 08-31-2017 02:16 PM |
Saturn Wax & Shine | saturnhusker | S-Series General | 28 | 06-11-2014 06:37 AM |
Night time driving: factory headlights too bright? | pix | Astra General | 34 | 01-13-2010 07:37 PM |
Should the green DRL light be on when driving at night? | molinee | General Saturn Discussion | 4 | 11-02-2006 12:04 PM |
Piston Soak Last Night- Vibrates Today Driving? | Leadsled Coupe | S-Series General | 7 | 10-27-2005 01:15 PM |
