#1 |
![]() Join Date: Sep 2014
Hello,
I have a 2002 Saturn SL, 109,000 miles 5 speed. About two weeks ago I started having a problem. My headlights and dashlights flicker when I get above 2200 or 2300 rpms. Also, the battery light has started coming on at the same time. If you drop to 2000 rpms or below, no problems (battery light goes off, headlights stay on). I've had the battery and alternator checked twice, no problem. Any ideas where I should look next would be greatly appreciated. |
#2 |
Unless you have a slipping belt, bets are still on the battery or alternator. I'd check with a meter and alter the rev range to see what voltages show. It's possible you have a connection or ground that is intermittent and only showing up at certain rev ranges, but IMO that isn't likely if it consistently relates to RPM.
Battery cables and connections can look good and have issues as well. But for charge to drop as revs rise isn't very common. |
#3 |
![]() ![]() ![]() Join Date: Aug 2012
2005 VUE 2.2L
'05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows. |
#4 |
Did you figure out what it is??? I was having a problem last year and decided to re[lace a seven year old battery. Six months later noticing problems coming back... I am going to try replacing the alternator next
Bookmarks |
Tags |
battery light, flash, flicker, headlights |
Intermittent cluster flicker after battery change | rijoemi | L-Series Tech | 3 | 05-15-2013 04:09 AM |
Weak Battery? - Lights flicker | RLFEEN | S-Series Tech | 4 | 09-26-2010 09:29 PM |
DRL indicator flicker | bryanb | S-Series Tech | 2 | 09-18-2008 11:26 AM |
All my lights tend to flicker | AtlantaMike | S-Series General | 3 | 03-19-2005 01:21 PM |
Low Cooland and Low Battery Lights both Flicker at the same time | HomeBase | S-Series Tech | 13 | 09-05-2003 12:42 PM |
