Old 10-12-2018, 10:42 AM   #1
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
Default Cyl 1 spark plug hole filling with oil.???
Hi, my 97 sc2 DOHC engine keeps filling the #1 cylinder spark plug hole with oil. I changed the valve cover gasket and it didnt help. Did I screw up? I checked the pcv valve and it rattles.. it only has 80k miles on it.
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 10-12-2018, 02:58 PM   #2
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: Cyl 1 spark plug hole filling with oil.???
My '98 was good after a new gasket. Same problem, #1 spark plug well. Others have had issues with the plastic valve cover.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-12-2018, 03:26 PM   #3
RobertGary1
1996 SC2
Yes, that's no uncommon. One common cause of leaks is the plastic valve cover warping. Go down to the junk yard and grab an aluminum cover from an older DOHC. Take the bolts too.
The plug wires could also be changed because the aluminum cover is slightly shorter so the ring on the wire is lower, although its a pretty minor detail and you could probably wait until you change the wires next.
-Robert
Old 10-12-2018, 04:36 PM   #4
timl865
Thanks. That's what I was thinking.
Old 10-15-2018, 03:17 PM   #5
timl865
Does anyone know what size tool I need for the metal valve cover? Is it a torx? Thanks!
Old 10-15-2018, 03:33 PM   #6
Everything you need to know
http://www.saturnfans.com/forums/sho...d.php?t=187908
Says T40
Old 10-15-2018, 04:27 PM   #7
timl865
Thanks. As always this forum is the best!
Napkin piece in spark plug hole dddaaa S-Series Tech 3 06-17-2012 09:35 PM
Uh, oh. Oil in spark plug hole Ikiris S-Series Tech 4 10-20-2010 04:10 PM
Spark Plug Hole Atrocity S-Series General 7 05-02-2010 10:26 PM
Dropped something in spark plug hole! d_rock S-Series Tech 7 12-09-2007 11:58 AM
oil in spark plug hole lawndoggy S-Series General 12 03-06-2006 11:32 PM
