Old 10-12-2018, 04:18 AM   #1
Packard
Packard is on a distinguished road
1995
Default lower or higher bypass oil filter which is better for sl1 95
Question Which bypass valve setting between these two filters is better for idle oil pressure on a 1995 sl1? I usuallly run my car at idle 1k to 2k rpm . What filter will offer the best lubrication at low speed travel between 30 -40 mph driving not fast .
filter #1 bypass 12psi
filter #2 bypass 9-12
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-12-2018, 07:08 AM   #2
Default Re: lower or higher bypass oil filter which is better for sl1 95
Why in the world would you need the idle at 2000 rpm?
If a 5-speed, you are going to remove years off of the clutch and if automatic, its still not good having to hold the tranny back as if it were a wild horse straining at the bit.
Old 10-12-2018, 07:26 PM   #3
Packard
1995
NO i just want to render at 6k fpms .
Old 10-13-2018, 01:25 AM   #4
Packard
1995
My question is pertaining low idle oil pressure . Does the higher filter have more restriction than oem with a 9 - 12 ?
Old 10-13-2018, 08:46 AM   #5
The filter element pressure drop is a function of oil viscosity and flow rate, the bypass setpoint has nothing to do with it. The bypass opens to bypass the filter element when the pressure drop across the element setpoint is exceeded. The 12# and 9#-12# specifications are functionally identical. The filter bypass should never open unless you insist in running gear oil or never change filters.
bypass oil filter rpl3000 L-Series Tech 4 10-25-2011 09:32 PM
Finally a Higher Performance oil filter for the Vue........ ImpalaSS Vue Tech 8 07-07-2008 05:46 PM
Attention MJO! Bypass-oil filter. SaturnFreek S-Series Tech 3 02-03-2007 05:03 PM
Ebay bypass filter Phonespider S-Series Mods 8 03-18-2006 10:20 PM
Anyone Using a Bypass Oil Filter? AndyH Vue Tech 7 01-11-2005 06:43 PM
