Old 10-12-2018, 12:42 PM   #1
dadinda
dadinda is on a distinguished road
Default 2005 Ion 2 cranks but won't start.
Had the ignition switch replaced for a recall. A few times it would not crank after we drove it. It just started working again and was fine for a long while. The other day It wouldn't do anything again. Then it would crank but not start. We have checked the ICM and coil pack and see no spark. Replaced the ICM and coil pack, same issue. We checked the fuel pump relay and fuse both good. We even tried disconnecting the battery for a while, did not work. Please help.
Add to dadinda's Reputation
Rate the quality of this post and help dadinda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dadinda is offline   Reply With Quote
Old 10-13-2018, 12:56 AM   #2
Default Re: 2005 Ion 2 cranks but won't start.
You're describing at least two issues - no cranking at all and cranking with engine not firing up.
Is security (Passlock) flashing during starting attempts? The recall to replace the ignition switch was supposed to correct random no start issue with Passlock inadvertently triggering on, disabling the starter circuit. The other issue with starting without the engine firing up isn't related to the ignition switch issue and adds a second problem.
Search in the Ion forums for similar issues and repost there to reach more owners that may have had the same problems and may reply.
Mileage, maintenance done besides what's already mentioned?
2005 saturn Vue cranks for a while before starting on cold starts dudebro420 Vue General 3 04-12-2017 02:43 PM
2005 ion - Cranks OK, but won't fire Astrocreep Ion General 1 08-16-2016 03:51 PM
2005 saturn vue cranks, No spark, fuel pressure or injector pulse iamfitness Vue Tech 0 11-08-2015 08:39 PM
2005 Saturn Vue 3.5L Cranks But Won't Start ArcticLeaf Vue Tech 9 12-03-2013 06:54 PM
2005 L300 168000 miles cranks but won't start gary078 L-Series Tech 4 12-04-2011 06:13 PM
