Old 10-12-2018, 05:55 AM   #1
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Poor heat from the floor vents
When I bought my SL2 new back in '99, there was one thing that was better on my old Dodge Omni. The Omni had awesome heat on the floor - you could feel it on your feet. Today I drove my '98 SL2 for the first time in near freezing temps. It was as good on my feet as the Omni. The '99 has plenty of heat, I am thinking there is an air diverter problem. My search attempt found a lot of Vue info, but no S Series. Anybody have experience working on the vent system that would help explain this?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-12-2018, 09:11 AM   #2
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
1995 SL2
Default Re: Poor heat from the floor vents
Does the recirc work? I dont know if that has anything to do with it, but it may. According to my 1995 owners manual it is supposed to have the max heat at the feet too.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-12-2018, 09:25 AM   #3
onlinebiker
onlinebiker is a jewel in the roughonlinebiker is a jewel in the roughonlinebiker is a jewel in the rough
What is your temperature gauge reading?
It should be about 1/3 of the way up, between 1/4 and 1/2.
The gauges are amazingly consistent. I have yet to see one that reads wrong.
92 SC2
93 SC2
93 SW2
95 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-12-2018, 09:46 AM   #4
Waiex191
Waiex191's Avatar
Recirc works. Temperature is above 1/4 both with the new thermostat after rebuild and the old one as it came from the factory. There is plenty of heat, just not on the feet.
I drove the '98 in today without recirc, but with toasty feet.
Bryan Cotton
Old 10-12-2018, 11:45 AM   #5
Waiex191, can you verify cooling system temps with a reader, hand held infrared temperature probe or thermometer inserted into the coolant container? Once system temps are confirmed above 190F, you might have to examine the hvac controls and hvac box. For whatever reason, I'm unable to upload drawings. Perhaps later.
Old 10-12-2018, 12:42 PM   #6
Here are some drawings.
Old 10-12-2018, 01:23 PM   #7
Look up high on the left side of the HVAC box and watch the linkage as you move the slider from far left to right. Watch the damper arm on the damper closest to the rear of the car. Check that the carpet has not managed top block the flor outlets which it can do easily.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
2002 SL2, not much heat at the vents toggenburg S-Series General 10 12-29-2017 08:01 PM
front heat vents blowing good on one side but not other? sc2 saturn S-Series Tech 9 02-25-2016 10:40 PM
2004 Ion AC Blows out Defrost and floor but NOT vents pelletman Ion Tech 2 05-09-2015 12:15 PM
Floor heat vents no worky. DavidBo Vue Tech 6 01-15-2015 02:27 PM
Hot Floor Vents!!!! Sad Outlook Outlook General 12 11-11-2007 10:53 AM
