#1 |
![]() Join Date: Aug 2009
I changed my shifter bushing about two weeks ago using a windshield wiper bushing as suggested on here for a quick replacement. I used the proper lubricant (teflon powder) and made sure the installation was correct.
It was shifting perfect, going straight into gear with good engagement and firmness. No more sloppy/hard shifting Well, about three days ago it started becoming real hard to get the car into second gear. It wasnt that bad at first, then it got worse, and worse, and worse. Yesterday while driving my girlfriend home from work I couldnt even get it in 2nd gear. I was cruising down the road and when i tried shifting from 4th to 5th the shifter went limp. Took the console off, shifter bushing still attached exactly how it was when i put it on. But underneath the hood, what I think to be the shift linkage to the transmission (right underneath the brake booster) there is a cable that is barely hanging on with one wire in the middle, and a bunch of steel braided wires that look like they have separated from something. Is this the shifter cable? if so, how hard is it to fix, and what might have caused this problem?
My first Saturn: 1996 SC2 5-speed Kill List: 2006 Mitsubishi Eclipse 5-speed 2003 Mazda 3 5-speed w/ CAI & Exhaust |
#2 |
Sounds like the shifter cables came detached from the transmission. Not unheard of before; it happens; but if you have the end that came detached to the transmission and it looks like twisted braided metal ends, it sounds very much so that you will need to replace the shifter cables.
There are two of them, and you don't have alot of space to work with in replacement through the Firewall. There are 2 (10MM) Bolts that hold a rubber grommet in place that the shifter cables will need to be fed through in the firewall as they make their way from the shifter tower to the transmission itself. You will need to get OEM SHIFTER CABLES ONLY!!! from a JY car that is in good shape. DO NOT USE Aftermarket cables, they WILL Break and put you in the same situation you are in right now.
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#3 |
oh yeah i know to use the OEM ones, i just finished reading your old thread about your shifter bushing replacement =)
I'll step outside and snap a quick pic of my problem and post it here
#4 |
http://i861.photobucket.com/albums/a...g?t=1254328697
This is the shifter cable i was telling you about that is all frayed and coming apart.
#5 | |
![]() Quote:
-Robert |
#6 |
no, that is right before the part where it comes into the transmission.
#7 |
I have been looking for threads on shift cable R&R and i cant find any, can anyone help point me in the right direction?
#8 |
Somebody please help ... OldNuc, FDryer, all the other smart people .. I know your out there.
#9 |
I found this thread, which details the replacement of the Manual Trans as an entire entity.
I didn't read through it completely; but there is mention with pictures of removing cables, etc. http://www.saturnfans.com/forums/sho...shifter+cables Also has a link to an online webpage created by the author with pictures. Hope this helps...
#10 |
I appreciate the help, now I at least know how to remove the cables from the engine, but what about the firewall, I have heard they are only attached by 2 10mm bolts, is this true, and how hard is it to replace the cable?
#11 | |
![]() Quote:
There is not alot of area to work around in down there, so it can be a pain. You will need to have the car up pretty high to gain some good clearance, or on a lift.
#12 |
getting the car up high is not an issue, i have a pretty beefy set of jackstands.
As for tools all i have is basic stuff like a full ratchet & screwdriver set, channel-lok, needle-nose, vise grips, very very basic tools. I just want to make sure i can get it fixed by this weekend.
#13 |
You'll also need to take out the center console to access the firewall and Grommet.
I'm only going on what I have read and what information my saturn mechanic has told me. If you have all the tools and some working ability to fix things, it may take a bit, but it is doable. I was going to do this myself when my cables went on my 94 SL2 in January of this year (it's been that long already? Wow.) But my mechanic friend said he could get it done quicker...He had my car on his personal lift to get the cables replaced...
#14 |
The center console is already out of the car. I took it off when i thought the shifter bushing had broken again, and when i discovered it wasnt, i just left the console off because i figured I would need to access the shift cables.
Another question: is the shifter cable in this car, a complete unit or 2 separate parts?
#15 | |
![]() Quote:
#16 |
Well yeah I can see both of those, and can see both of them connected to the shifter. My actual question, and I should have been more specific, is ...
is the shifter cable 2 separate metal cables connected together underneath that grommet? or is each of the 2 cables just one big metal cable? A better way to revise my question, would be ... is there 2 pieces to each cable or just one?
#17 |
As far as my understanding, they are each a seperate cable that each connects to each side of the manual trans.
2 Cables, that are each 1 piece per cable...if that makes sense one left, one right.
#18 |
makes perfect sense. my next question is ... how do i get the cables into the cable end loop?
#19 |
It's two cables that work independently. One moves with left-right shifter movement and the other moves with fore-aft shifter movement. They have to be replaced at the same time, however, since the two cable housings are bonded to the firewall grommet.
#20 |
so i need to pull both cables from the JY and not just the broken one?
The only other question i have left is, how do i remove the eyelets from the shifter end of the cables?
Bookmarks |
binding shifter and shift linkage? | Melissa_M | S-Series Tech | 26 | 12-02-2009 07:17 PM |
shifter linkage connection on 98 SL1 | abinder | S-Series Tech | 0 | 05-26-2009 08:29 AM |
98 SL2 Shifter Linkage? | wolfehunter | S-Series General | 13 | 03-01-2009 07:47 PM |
shifter cable help | joshusmc80 | S-Series Tech | 6 | 12-19-2008 04:29 PM |
'99 SC1 Shifter Linkage | Buck4U | S-Series Tech | 6 | 03-20-2008 11:09 AM |
