#1 |
![]() Join Date: Dec 2008
I am adding a Navigation System to my wife's 2007 Vue Redline. After doing much research and reading a ton of reviews I have decided on the Eclipse AVN-6620. The Eclipse AVN-6620 is almost identical to the navigation and GPS systems found in all high end Toyota and Lexus cars. If I could wait until next year I would get the The Eclipse AVN-726E, hard drive based, that is the next-generation of the Eclipse Navigation.
![]() http://www.eclipse-web.com/avn/avn6620overviews.html Eclipse AVN-6620 DVD Navigation Receiver $799.99 Eclipse SIR-ECL2NT Sirius Nav Traffic Tuner for AVN-6620 $299.99 Eclipse RMC105 Infrared Remote Control for Car Audio $19.99 Eclipse BEC106 Rear View Camera for AVN models $239.99 To make the Navigation work with the ONSTAR I am using the Axxess GMOS-LAN-06 LAN OnStar Interface for Saturn Vehicles $106.00 ![]() The Problem everyone seems to be having is finding the SPEED PULSE SIGNAL, but I think I have found the answer: This is for a 02-07 Saturn Vue to add speeed pulse, but might help To get the Speed Pulse Signal from the VSS, Check Out the Link Below: http://www.avic411.com/forum/viewtop...244f94b8562e1a To get the Speed Pulse Signal from the VSS you need to tap into the "WHITE WIRE" that comes from the "Engine Control Module" (Below BAttery Cooling Box) to the "Wheel Speed Conditioner Module" (Behind Left Front Console Trim Panel). Last edited by vroomz28; 12-11-2008 at 12:49 PM. Reason: correcting errors |
#2 |
SPPED PULSE DIAGRAM
The Problem everyone seems to be having is finding the SPEED PULSE SIGNAL, but I think I have found the answer: This is for a 02-07 Saturn Vue to add speeed pulse, but might help To get the Speed Pulse Signal from the VSS, Check Out the Link Below: http://www.avic411.com/forum/viewtop...244f94b8562e1a To get the Speed Pulse Signal from the VSS you need to tap into the "WHITE WIRE" that comes from the "Engine Control Module" (Below BAttery Cooling Box) to the "Wheel Speed Conditioner Module" (Behind Left Front Console Trim Panel). ![]() Last edited by vroomz28; 12-11-2008 at 12:50 PM. |
#3 |
![]() Join Date: Mar 2009
2007 VUE 2.2L
1993 SL2
hello. i m a newbie here. i just bought a pioneer avic f900 nav/gps for my 07 vue and i'm seeing i'm not the only one with the problem of knowing where to tap into for the vehicle speed signal. according to this topic thread, it states to tap into the White wire thats going to the "Wheel Speed Conditioner Module" (Behind Left Front Console Trim Panel). my dumb sounding question is... where is the left front console trim panel? if i'm sitting in the driver seat where do i look for it? is it under the dash where the gas/brake pedals are? thanks for any help you guys give.
Bookmarks |
Tags |
avn-6620, navigation, onstar aftermarket stereo, speed pulse, vss |
Install OEM Navigation in Non Nav 08 Vue RL | BigD_Redline | 2008 Vue | 14 | 12-29-2009 10:35 PM |
Pioneer In dash entertainment system install help | dunkchamp55 | Vue General | 8 | 02-02-2009 12:12 PM |
Can you install a navigation system in an 09 XE? | sfiermon | Outlook General | 2 | 01-20-2009 02:44 PM |
2008 Vue Redline Aftermarket In-Dash DVD/GPS Install | BigD_Redline | Vue Mods | 21 | 07-27-2008 12:00 PM |
Should Saturn an Offer In-Dash Navigation System in its Vehicles? | Charlie | Polls and Questions | 19 | 05-23-2004 09:39 PM |
