Old 03-25-2014, 12:49 AM   #1
ChrisKC
ChrisKC is on a distinguished road
Default Door skin compatibility
I have bashed up driver door on my 06, wondering what year door skins will work since the whole thing is trashed and keeps catching when you open the door.... Also happens to be black so wondering if anyone has had to paint a Saturn door panel and how best to do so. Hoping I get lucky and find black..
Add to ChrisKC's Reputation
Rate the quality of this post and help ChrisKC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ChrisKC is offline   Reply With Quote
Old 03-25-2014, 01:19 PM   #2
PortugalFocus
PortugalFocus is just really nicePortugalFocus is just really nicePortugalFocus is just really nicePortugalFocus is just really nice
PortugalFocus's Avatar
Default Re: Door skin compatibility
Pictures would significantly help. "Bashed up" and then requesting just a door skin don't seem to mesh. Where are you located?
Punctuation and proof reading may also positively assist in your query.
Michelin LTX M/S2's // MOMO // Razzi Spoiler // Westin // Hella // K&N // Clear Corners
V6 Air Bag and Steering Wheel Swap
http://www.saturnfans.com/forums/showthread.php?t=155754
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PortugalFocus is offline   Reply With Quote
Old 03-25-2014, 02:28 PM   #3
ChrisKC
By bashed up it mean damaged, instead of denting, the body panels tend to crack. The entire front edge of the door skin is cracked leavin it sticking out so it catches the front fender when you open the door. My plan is to undo the torx screws and take the cracked skin off and replace it from one I've pulled at the junk yard. The door itself is fine I just need the skin, or body panel for the outside of it.
Old 03-25-2014, 05:18 PM   #4
PortugalFocus
You can simply swap the door skin from 2002-2007. However, you do need to remove the front door panel first and detach the outside door handle first, from the inside. Once that is done, double check there is nothing else keeping it attached to the door frame and go from there. Luckily, silver, white, black and red were two of the colors that didn't change paint code and were identical throughout the VUE run. I see you have black.
Good luck, hope that helps.
Old 03-25-2014, 11:23 PM   #5
ChrisKC
Yup exactly what I needed, thanks. Door skin, driver headlight, and air box all on my list for tomorrow
Old 03-26-2014, 11:33 PM   #6
ChrisKC
Actually found a door skin! But in silver... So getting it painted will cost a fortune... But come to find out the door can be removed with everything else intact. A small pin on the bottom side of the handle can be pulled and the handle then breaks free with a tap and comes off, then lift up ( mirror does have to be removed) and it's off... Now to figure out paint. Can't beat $17 for a door skin but $200 to paint it seems a bit steep...
SW2 door skin coolcat2 S-Series General 3 01-17-2010 12:35 AM
95 sw door skin coolcat2 S-Series General 2 09-12-2009 01:12 AM
can't get door skin off 93SC2'in S-Series Tech 3 01-04-2009 10:17 PM
wanted to buy sl1 door skin racerx217 Classifieds 0 04-22-2006 11:49 PM
WTB: SL door skin CMSchops Classifieds 0 03-28-2005 01:50 PM
