Old 10-21-2018, 03:18 PM   #1
EchoMirage
EchoMirage has a spectacular aura aboutEchoMirage has a spectacular aura about
EchoMirage's Avatar
Question E Brake button flew out
the woman goes to put the E brake on, and instead of pushing the button in and pulling the handle, she yanks up on it. apparently, according to her, the button flew out of the handle by itself. she found it, and stuck it back in, but now theres no spring behind it, and you cant put the brake on. it wont lock by itself.
is there a fix to this? has it happened before, or is this some weird thing that only happens to her? will this be another junkyard run for a complete e brake handle?
When tyranny becomes law, rebellion becomes duty
95 SL2 bought in 8/14 with 23K original miles
Add to EchoMirage's Reputation
Rate the quality of this post and help EchoMirage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EchoMirage is offline   Reply With Quote
Old 10-21-2018, 03:54 PM   #2
RobertGary1
1996 SC2
Default Re: E Brake button flew out
Yea just glue it back in. The spring on the button really serves no purpose and the spring action comes from the movement of the plastic push assembly. We used to think you had to change the assembly (richpin even did a video on it) until we realized this wasnít necessary. Just Home Depot glue.
-Robert
Old 10-21-2018, 03:56 PM   #3
Oh, I'm sure it has happened before, to Saturns and other similar lever brakes, but not terribly common. You are going to need the spring, so your choice about guessing what it should be (not all that hard to do) and getting one at local hardware store, or just replacing the whole lever assy.
PS: If the lever can come up far enough for that button and spring to pop out, the brake adjustment is way off. That adjustment should be automatic, so something is wrong with the brakes/cable/etc. Find that root cause as well as fixing the lever. I'm assuming this lever was pulled by a "normal" woman, not an ex-Soviet steroid-laden Olympian.
Oh, and another PS: There is no need to push the button when pulling the brake on, the button is only needed to release the lever. What did you mean at the beginning by this? "goes to put the E brake on, and instead of pushing the button in and pulling the handle"
Add to billr's Reputation
Old 10-21-2018, 04:01 PM   #4
RobertGary1
1996 SC2
Itís actually a pretty common issue on saturns. Itís caused when the little tabs that hold the button against the spring start to bend. Brake adjustment should be fine. But you can just glue the button back on the white plastic lever and it will work good for a decade.
-Robert
Old 10-21-2018, 04:10 PM   #5
OK, I'll have to go peek at one of mine. It seems like a pretty simple and reliable device, hard to imagine how it would fail in normal use...
Old 10-21-2018, 05:00 PM   #6
Packard
Packard is on a distinguished road
1995
If u lost the spring the button is held in with a spring I had to replace mine a while back been good for 3yrs now I just bought
new since this is brake that holds the car I wanted a reliable brake .https://youtu.be/cCbsYlUoZE4
Search for Saturn S Sl Sw Series 1995 Emergency Hand Brake Button on ebay or look it up on gmonline that handle Im sure can be had for alot less . Its amazing how they can charge 18 bucks for this plastic still worth it when it comes to either not being able to park your car on hill its a major headace so the 20 bucks is more then worth the safety.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-21-2018, 05:04 PM   #7
RobertGary1
1996 SC2
Originally Posted by Packard View Post
If u lost the spring the button is held in with a spring I had to replace mine a while back been good for 3yrs nowhttps://youtu.be/cCbsYlUoZE4
Yea but we later discovered it was unnecessary to replace. Just glue the button to the plastic lever. You canít tell the difference. Did mine 5 years ago.
-Robert
Old 10-21-2018, 05:09 PM   #8
Packard
1995
Mine was not able to hold the sping no more the button was too bad so i need one . Was scary i dont know how to macgyver so i had to buy it.
Old 10-22-2018, 03:19 PM   #9
button flying out is very common
http://www.saturnfans.com/forums/sho...d.php?t=142078
Old 10-22-2018, 04:26 PM   #10
RobertGary1
1996 SC2
No mater how mangled up the button is if you weld it to the plastic lever its not going anywhere. Only regret I have with mine is that I welded the button upside down. Works fine but irritates me.
-Robert
Old 10-23-2018, 02:00 PM   #11
EchoMirage
EchoMirage's Avatar
Ok, so how do I take the lever apart. Is it just that one screw? I have a feeling the spring flew out too, because she put the button back in, but there's no spring behind it.
Old 10-23-2018, 02:51 PM   #12
RobertGary1
1996 SC2
Yep easy. Just remove the screw and pull the sheath off. Yes the spring is probably under a seat somewhere.
-Robert
Old 10-24-2018, 12:24 AM   #13
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
1996 SW2
2000 SW2
Put the spring on then button. Drill a small hole through both tabs and the white mounty thingy. Loop a paper clip through it and call it a day. 3-4 years on mine. Think that's the link above.
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 10-24-2018, 12:36 AM   #14
1996SW2
1996SW2's Avatar
1996 SW2
2000 SW2
I responded to an old tgread liked below...lol
I used a hair pin instead of paper clip
Old 10-24-2018, 12:55 AM   #15
1996SW2
1996SW2's Avatar
1996 SW2
2000 SW2
Third time is a charm.
File Type: jpg PhotoPictureResizer_181023_215116659-1328x747.jpg (47.7 KB, 9 views)
Old 10-27-2018, 10:08 AM   #16
EchoMirage
EchoMirage's Avatar
hopefully ill get around to it soon. i told her to just park on level ground until then. not being my driver anymore puts it on the back burner in terms of repairs. im sure ill need a spring for it.
Old 10-28-2018, 05:19 PM   #17
EchoMirage
EchoMirage's Avatar
fixed it. even found the spring in 2 seconds of looking. wouldve fixed it faster if i knew the spring actually rests on the metal handle, not the plastic one. lets see how long it lasts now. i didnt have to glue anything, but i see where it can be glued.
WTB: E-Brake Button, 99 SL (2nd Generation) 2NDSOUT Classifieds 0 09-29-2016 01:23 PM
Brake Button Assembly adam22 S-Series General 2 07-06-2014 01:44 PM
Handbrake Button - Parking brake handle button EarlyMR S-Series General 28 07-08-2012 09:29 PM
UH OH! My E-Brake button shot out! Ikiris S-Series Tech 2 07-15-2010 05:50 PM
e-brake button down the shaft! rgierer S-Series Tech 3 12-05-2007 12:48 AM
