Old 07-13-2018, 09:02 PM   #1
DrHax
DrHax is on a distinguished road
Default 2002 sc2 leaking automatic transmission
Hello I am working on my friends 2002 sc2 saturn. Well he came to me with a leak. I found out the oil cooler lines were leaking. We replaced the lines/ We drained the system replaced the filter filled it up with new fluid to have it draining from the bottom of the transmission at the spot between the bell housing and the engine. Its the very bottom.
So I'm trying to figure out exactly just what it can be, and can not be. What we should we be doing next.
I can remove the transaxle assembly. I've done engine swaps on other cars, so I have the tools. We just need to figure out what to look for.
Add to DrHax's Reputation
Rate the quality of this post and help DrHax reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrHax is offline   Reply With Quote
Old 07-13-2018, 10:41 PM   #2
billr
Default Re: 2002 sc2 leaking automatic transmission
I sounds like it could be the "diff pin" has come loose; search on this forum and you will find many threads relating to that pin. It is a near-fatal condition for the trans, you will need replacement from a JY if that pin has come loose. Unless you know a good welder, and even then the trans axle has to come out and be substantially dis-assembled.
You can check that pin by removing the vehicle speed sensor (VSS), a fairly easy job. That inspection is outlined in some of those threads you will find.
Add to billr's Reputation
Old 07-13-2018, 11:36 PM   #3
DrHax
what metal is the transmission I'm a certified welder. Is there any chance its a seal of some sort? Either way it sounds like the transmission has to come out.
Old 07-13-2018, 11:50 PM   #4
Mike R
Mike R is on a distinguished road
2000 SL2
When my diff pin came out the only thing I welded was the pin to the carrier. The groove/hole in the case was repaired with JB Weld, three years and not a drip. Was told by my buddy the Dodge mechanic to repair it like this, he said it was a common problem and that was how Chrysler had them do it ( the case not the welded pin)
2001 SL1 5 speed
2000 SL2 Automatic
Add to Mike R's Reputation
Rate the quality of this post and help Mike R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike R is offline   Reply With Quote
Old 07-14-2018, 12:16 AM   #5
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
1996 SW2
2000 SW2
Maybe you pured too fast into the funnel and air bubbles broke the seal from dip stick tube and funnel. Resulting mess was about a half court on the floor. luckily I still had a drip pan under. This was, literally, 10min ago
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 07-14-2018, 12:22 AM   #6
DrHax
Cool good to know. So even if it is this dreaded pin thing I think I should be able to fix it. that would be good news for my buddy as he's flat out broke. He needs this car.
Old 07-14-2018, 01:47 PM   #7
billr
Personally, I wouldn't weld the diff pin; I would put in the bigger spiral type spring pin. However, I can believe welding the diff pin can work in most (all?) failures of this type.
The welding I'm talking about is repair of the trans case/bell-housing. Whether you can patch it with epoxy or FRP depends on how bad it is damaged. Inspection of this particular one is needed to determine how bad it is.
Old 07-14-2018, 05:27 PM   #8
DrHax
I'm presuming the case is a cast aluminum. Which is a challenge to weld.
I suspect the hole if there is small.
Welding the diff pin I don't think is going to be too challenging.
Old 07-15-2018, 09:40 AM   #9
I haven't been under the car in a long time, but make sure of where the leak actually is - it will drip down to a low spot. Some leaks have been simple overfills (auto trans fluid should be at the halfway mark on the dipstick when hot, not at the top of the hashes).
Double check the filter, too, for leaks. Could blow back when driving and end up down there
Old 07-15-2018, 10:53 AM   #10
Saturn Night
Has this car had the engine recently pulled out if it for any reason?
It sounds like another possible cause of THIS leak is the front seal to the transmission.
Removing the engine and movement of the torque converter can cause this seal to leak when the engine is reinstalled.
The fluid will leak at the lowest point in the bell housing, which there is an aluminum bracket in that area, that bolts to the bottom of the block.
I have seen photos of a thrown differential pin, on Sixthsphere's Facebook page. The differential pin causing a leak will be obvious.
2002 Vue 3.0L V6 AWD automatic transmission fluid Jackdude9998 Vue General 2 05-14-2018 11:52 AM
How and where can i find a 2002 sc2 automatic transmission Dakota Rockwell S-Series Tech 4 11-09-2014 03:55 PM
1999 saturn sl2 rebuilt automatic transmission leaking fluid ahyat S-Series Tech 12 08-26-2014 08:05 AM
1995 SL2 Automatic Transmission leaking? KingRex S-Series Tech 6 02-17-2009 03:57 PM
2002 SL2 Automatic Transmission Problems leia99 S-Series Tech 4 12-11-2007 05:51 PM
