Old 07-13-2018, 05:28 PM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Chirping noise under the hood...
Minor chirping noise under the hood, assuming itís the belt tensioner...
I know I need the 90 mm larger, I have a 780 serpentine belt
(Verses the 78 mm and 778 belt)
I am assuming the Dorman parts are bad news, correct?
I see two AC Delco tensioners on Rock Auto, assuming the cheaper one is old stock?
Any recommendations?
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 07-13-2018, 06:16 PM   #2
Default Re: Chirping noise under the hood...
Most likely serpentine tensioner, however; just be sure it's not one of the other devices being pulled around by the belt...like AC compressor, water pump, the idler pulley or the alternator....just saying
Old 07-15-2018, 03:11 AM   #3
KNGRK9
KNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura about
I had this issue for a bit with my Saturn. Wasn't belt related but rather one of the hoses near the firewall can't remember which
1999 SL2 HCE - 245k (wrecked)(rebuilding)
2004 Ion Redline - 108k
Add to KNGRK9's Reputation
Rate the quality of this post and help KNGRK9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KNGRK9 is offline   Reply With Quote
Old 07-15-2018, 09:15 AM   #4
Saturn Night
To test the belt tensioner, you will need a very long 13mm wrench and the engine idling.
Put the wrench on the pulley bolt and tighten it with a little pressure. If the chirping goes away, then the tensioner is starting to wear out.
If it doesn't go away, there are two other possibilities:
The Alternator
Water Pump
Power steering & AC have different symptoms, in addition to chirping/squealing, when the bearings begin to fail within them.
You may also notice the plastic seal is hanging out partially, on the stock tensioner. They typically last about 150,000-175,000 miles, under normal driving, wear conditions, and driver treatment of the car.
2005 Vue - noise under hood - chirping, then squealing JVD4 Vue Tech 8 12-12-2014 06:25 PM
A/C no cold and chirping noise feiniaoyu L-Series Tech 4 07-28-2009 10:49 AM
Chirping Noise From Torque Converter. I think! SL1Joe S-Series Tech 1 11-16-2007 08:14 PM
clicking/chirping noise zpurdy S-Series Tech 11 02-26-2007 04:12 PM
Chirping Noise under hood JayNYC S-Series Tech 10 06-18-2004 08:58 AM
