Old 07-13-2018, 07:56 PM   #1
StrnWolf
StrnWolf is on a distinguished road
1995 SL2
1994 SL1
Default The Truth About Fuel Filter and MPG?
So after a good compression test I am wondering if I should bother replacing fuel filter. I may be wrong bit it appears someone has replaced the hose between filter and fuel rail, I assume that it has a lock fuel fitting at the fuel rail? But this one has just a regular hose pushed onto it and no hose clamp.
I want to finally get a definitive answer on a question about fuel filters. I have heard that you can get better MPG and SMOG results with a new filter, but for a 95 SL2 is that true? The way I picture it a used up fuel filter will deliver less fuel to the engine but I have heard that it actually forces more fuel into engine. Can anyone give me the actual answer on that?
07/2018-PRESENT 1995 SL2
12/2009-PRESENT (Soon to die) 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 07-13-2018, 08:39 PM   #2
toggenburg
toggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to behold
toggenburg's Avatar
Default Re: The Truth About Fuel Filter and MPG?
Clogged up filters will reduce the flow, never increase flow of any fluid.
Think about it.
toggenburg is online now   Reply With Quote
New fuel pump/filter no pressure out filter????? Justross1979 General Saturn Discussion 14 06-11-2017 12:11 PM
Parts Master fuel filter vs Wix fuel filter AprilSL1 S-Series Tech 21 08-05-2014 08:43 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 06:29 AM
Oil Filter "Stuck" - just searching for the truth. kim_lombard Vue General 16 06-26-2007 09:20 PM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
