Old 07-13-2018, 06:56 AM   #1
Elwood187c
Elwood187c is on a distinguished road
Default Wiring after new clutch.
Hello everyone,
I have just replaced the clutch in my 2007 saturn ion. Clutch Grabs great, but I do not know what wires go back to the temp sensor for the engine coolant. Also, I have had trouble before I replaced the clutch with the p0117 code. I replaced the thermostat, the ect sensor and still nothing. Any suggestions would be much appreciated, thank you.
Add to Elwood187c's Reputation
Rate the quality of this post and help Elwood187c reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Elwood187c is offline   Reply With Quote
Old 07-13-2018, 01:38 PM   #2
Default Re: Wiring after new clutch.
Unless wiring color codes changed, the two wires for the coolant sensor should be yellow and black. If the correct connections are there, check for damage to the male/female pins/sockets and wires.
Wiring Diagram or wiring advice dasdream Astra Tech 3 07-25-2017 09:13 PM
HELP: 03 Ion Clutch Pedal Switch Wiring nickroa95 Ion Tech 19 11-21-2016 06:21 PM
2003 Vue VTI to manual clutch wiring jem62 Vue Tech 11 02-21-2016 04:38 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
Clutch fluid level, clutch pedal vibration, small leak Heartbeat - '95 SL2 Miscellaneous Tech 10 10-10-2003 05:35 PM
