Old 11-13-2018, 03:11 AM   #1
Jake3240
Jake3240 is on a distinguished road
2000 SL2
Default Quill / input shaft bearing- where to buy?
I just pulled my transmission to replace the clutch and found the disc coated in ATF. I've searched around and looked through hunting4steve's rebuild post, but I started looking around for the seal, and can't find it anywhere. I've looked on rockauto, summit, amazon, all the local store websites, and a few gm parts websites. One of the GM parts places said it is discontinued, and summit said they didn't have any. Does anyone know of a place to source this bearing/seal? I believe the part # is 21120405 from another post. Am I SOL if I can't find one? I'd hate to put a junkyard transmission in it only for it to do the same thing in a year. I was thinking maybe drill a drain hole in the "sleeve" part of the old one right next to the bellhousing to keep the oil from going right on the clutch disc. Any help is appreciated.
2000 SL2 5 speed
265k
Add to Jake3240's Reputation
Rate the quality of this post and help Jake3240 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jake3240 is offline   Reply With Quote
Old 11-13-2018, 04:59 AM   #2
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Re: Quill / input shaft bearing- where to buy?
This?
https://www.rockauto.com/en/catalog/...t+bearing,8708
NGK BKR6E-11 spark plugs
Old 11-13-2018, 07:59 AM   #3
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Maybe check with these guys what their kits contain.
http://www.drivetrain.com/parts_cata...ts/saturn.html
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-13-2018, 10:22 AM   #4
Jake3240
2000 SL2
I tried rockauto first. When I put it in my cart, an error message came up saying it wasn't in stock. I'll try drivetrain.com.
2000 SL2 5 speed
265k
Old 11-13-2018, 03:42 PM   #5
mattwithcats
GM Parts Giant
https://www.gmpartsgiant.com/parts/g...-21120405.html
https://www.gmpartsdirect.com/oem-pa...aring-21120405
Old 11-13-2018, 06:23 PM   #6
Jake3240
2000 SL2
I called the guy from drivetrain.com and he was very helpful, eventhough he didn't have it himself. He called his GM guy and checked the nationwide database. They confirmed it was discontinued and said only 9 dealer parts departments in the country had any old stock. The closest one listed in NC didn't actually have it, but the one in Salem, VA did and is shipping it to me.
Guess you better get them while you still can. Seems like a bad design to dump ATF onto the clutch when the seal goes bad.
2000 SL2 5 speed
265k
Old 11-13-2018, 07:04 PM   #7
All manual transmissions have some type of seal on that shaft. A failed bearing is a disaster but a leaking seal can be worked around. You do not have to go that way as you have located the OEM part. Be sure to look at the search4steve thread on exactly how to remove and replace that assembly as you can destroy the housing by doing it incorrectly.
Infamous input shaft seal (quill bearing) questions I could not find answers to The Mad Hatter S-Series Tech 10 08-19-2015 08:58 AM
Replacing Trans Input Shaft bearing/seal Speedrc99 S-Series Tech 2 10-06-2013 06:18 PM
MP3 Input Shaft Bearing Part Number Help Greg1 S-Series Tech 2 02-12-2012 10:52 PM
Replacing input shaft seal/bearing Khandyman S-Series Tech 1 01-16-2007 04:18 AM
Quill Bearing? bobke1 S-Series Tech 4 02-04-2006 01:30 PM
