Old 04-30-2019, 12:46 AM   #1
RobertGary1
1996 SC2
Default Fuel pump brand
In 275,000 miles the car has never failed to start (other than occasional battery). Drove down to San Jose and it didnít start. Banging on the tank eventually got it started.
Whatís the best brand (even if itís $$)? Denso makes one. Or is junk yard better? I know there are really bad aftermarket ones there.
-Robert
Old 04-30-2019, 08:02 AM   #2
Default Re: Fuel pump brand
I would never pull a fuel pump from a wreck, always go with new. Denso is good, and around $70 off ebay.
Old 04-30-2019, 01:17 PM   #3
Carter and you may have to do some searching for the part numbers as it is the complete pump unit. There are 2 98 and newer and then 97 and older. Nothing else is recommended.
RockAuto has it: CARTER P74949M also check Amazon and eBay for best price.
Old 04-30-2019, 04:49 PM   #4
I stand (or sit) corrected
Carter;
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
Old 04-30-2019, 10:53 PM   #5
RobertGary1
1996 SC2
What became of Delphi? They used to be good.
-Robert
Old 05-01-2019, 08:37 AM   #6
Delphi is gone and AC Delco is a reboxer of the generic aftermarket part at a higher price.
Best fuel pump brand? bobbyrae S-Series Tech 11 02-04-2015 07:40 PM
Brand new fuel pump with no pressure kingkevin8 S-Series Tech 17 11-01-2013 11:04 PM
Fuel Pump Troubleshooting results. Bad pump? saladdin S-Series Tech 13 02-14-2013 10:39 AM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 12:34 PM
What brand water pump is good to use? turbobuick33 S-Series Tech 6 02-09-2008 03:56 PM
