Old 11-08-2011, 06:24 PM   #1
brianolda
brianolda is on a distinguished road
Default code P0420 Need help
this code means catalyst system efficiency below thresh hold. Does any one know what this means????
Add to brianolda's Reputation
Rate the quality of this post and help brianolda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brianolda is offline   Reply With Quote
Old 11-08-2011, 06:31 PM   #2
BV22
2002 SC1
Default Re: code P0420 Need help
It usually means the catalytic converter has reached the end of its useful life and must be replaced to pass emissions. Occasionally, a failing rear O2 sensor can give this code. Year, model, mileage and oil consumption rate of your car would help.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 11-08-2011, 06:46 PM   #3
brianolda
Yes I bet it would. 1998 SL1 SOHC Frsh rebuild on the motor. Thanks for the help
Old 11-08-2011, 07:27 PM   #4
A 420 can throw from something as simple as an exhaust leak upstream of the rear O2 sensor. Check the manifold/downpipe joint (uh-oh, I wrote "420" and "joint" in the same post....), around the flex-pipe, and the inlet to the cat. If the rebuild was recent, the manifold/downpipe connection may be a bit loose. Doesn't take much; I had ONE of the three downpipe flange nuts loose, maybe 1/4 turn, and that was enough to throw a 420.
Add to madpogue's Reputation
Old 11-08-2011, 07:30 PM   #5
Pull the PCM B fuse(UHJB) and then replace it. Go for a drive and see if the 420 comes back. The 420 may be the result of the rebuilding or it also can be caused by any exhaust leak between the head and CAT inlet. Hold a towel on the exhaust and feel for leaks, a very small one is all that is required to do this.
Old 11-09-2011, 12:24 AM   #6
td1238
A P0420 can also be caused by a cat converter that's being heavily taxed, but isn't necessarily at the end of its useful life.
On one friend's car it was a weak ignition coil that was causing a misfire on one cylinder. This both sends unused fuel and unused oxygen into the exhaust. Replacing the ignition coil eliminated the misfire, and within moments the P0420 code also went away, and has been gone for over a year now.
On my '99 SL2 it was weak ignition coils, a burned exhaust valve, imbalanced injectors, and moderately heavy oil burning. At 219,000 miles of this abuse I was able to partially revive the cat, but in the end I wound up replacing it.
On another friend's car it was a faulty upstream oxygen sensor that was causing the engine to run too rich. Replacing the oxygen sensor made the engine run far better, and has caused the P0420 code to go away for months now.
In the cases where the code went away, the cat was taxed, but not enough to destroy it. Fixing the problem in a timely manner saved the cat.
Oil burning can clog the cat, and long-term oil burning can destroy it.
See to it that your ignition coils are in good condition (measure over 8k ohms at room temperature), and that the ignition system in general is well maintained, that your injectors are clean, oxygen sensors are functioning properly, all other sensors (temp, TPS, MAP, etc.) are functioning properly, that there are no exhaust leaks, especially before the cat, and that the engine doesn't burn excessive amounts of oil and absolutely no antifreeze (just in case). Then, if the P0420 code won't go away, you likely will have to replace the catalytic converter. Absolutely do not replace the converter until you are sure that all other faults are eliminated from the engine, and only after you cannot get the code to stay off.
Add to td1238's Reputation
Old 11-10-2011, 12:39 AM   #7
td1238
Another common cause for a misfire (which can cause a P0420 code) is oil on the spark plugs and boots. I didn't think of this until I read another post, but on cars where the spark plug passes through the valve area, oil leaks are common here. If there is a lot of oil around the plug, it can cause it to misfire, especially when under load, which can tax the cat and throw a code.
Consider all possibilities mentioned. ...And again, absolutely do not replace the cat until all engine performance issues (including excessive oil burning) are corrected, or until the code cannot be cleared (sometimes, once the engine problem is corrected, the cat resumes normal performance, and the code disappears). If the problem(s) is not corrected, it will only ruin a new cat.
P0420 Code ezzieyguywuf S-Series Tech 33 05-03-2011 05:33 PM
code P0420 Frankd1 S-Series Tech 9 11-14-2009 10:13 AM
help i got a code that is P0420 butters122706 L-Series Tech 0 06-13-2009 11:00 AM
Another P0420 code alleninpa S-Series General 7 09-02-2007 03:03 AM
P0420 Code angelaw S-Series General 9 11-22-2006 09:47 AM
