Old 07-22-2018, 08:51 AM   #1
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Default TRS 2/TCC fuse blowing.
2001 SL2 143K
Existing fuse was blown. Put in a new fuse and it blew on a 22 mile/20 minute drive.
Do I need a new solenoid?
Forward slam when doing 3/4 upshift and downshifts. Torque converter won't lock up.
All other shifts are fine, no reverse slam.
Getting ready to buy a new one on Amazon for $50. Just want to make sure there isn't something else I should check first.
Thanks.
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 07-22-2018, 09:30 AM   #2
Default Re: TRS 2/TCC fuse blowing.
Step #1 is check the solenoids cold resistance and top connector for heat damage. Replace all failed solenoids.
Old 07-22-2018, 09:47 AM   #3
DonP1
Dang - it can be more than 1?
What causes these to go bad?
Edit: I just watched a youtube video. I've been talking to Joe / Special Forces, and if I'm going to go through all that hassle to check the solenoids, I'm just going to get the new valve body with the new solenoids in it.
Old 07-22-2018, 10:41 AM   #4
You won't get new solenoids, you will get used ones that have been checked the same as you can do in about 1/2 hr. More to the point, the problem is probably a short in the harness or connector. Possibly the bus plate on the VB, but I think that is less likely. Open connections on the bus are fairly common, but not shorts. Likewise, the solenoids tend to fail open, not shorted so bad as to cause severely high current. Besides, I expect the PCM drivers for the solenoids are self-protecting to limit current in event of a short.
Got it? I think power from that fuse is shorting to ground before it even gets into the trans.
Add to billr's Reputation
Old 07-22-2018, 10:48 AM   #5
DonP1
Yes, that makes good sense. You would think the solenoids would burn open.
So I will get down and pull the wiring connector just to check the solenoids from the outside just to make sure..
But if it is a wiring short, how to fix this? It would have to be one of the control wires touching a ground?
FYI this Saturn had an ECTS wire that was all crushed up as well. I don't know how these things happen.
Old 07-22-2018, 11:37 AM   #6
Actually these solenoids can fail in the low resistance direction and not then go open circuit. This is why you actually check resistance on these things.
Old 07-22-2018, 11:38 AM   #7
Good idea. Those are used properly tested solenoids so you know they are good and teh buss plate is functional.
The solenoids fail from heat and vibration. There are multiple turns in each layer of winding and multiple layers. Layer to layer shorts are rather common.
Fuse Keeps Blowing travisj027 S-Series Tech 4 06-19-2015 08:49 AM
SL2 park fuse keeps blowing, and blowing Herbivore S-Series Tech 13 02-23-2015 11:52 AM
A/C blowing fuse larryssaturn S-Series Tech 9 04-06-2011 10:27 PM
hi and need help. blowing fuse allen57 S-Series Tech 1 04-15-2007 09:42 PM
Fuse keeps blowing...WTF Wifey's Ride S-Series Mods 9 04-20-2006 08:22 PM
