#1 |
![]() Join Date: Nov 2006
1992 SL2
1992 SL2
I'm working on a 92 sl2, and my rear passenger brake cylinder just went, I have the new part, but the two bolts holding it are completely stripped. how am i going to be able to take the busted cylinder off?
#2 |
Well if you got a new cylinder, find a grinder and grind the heads of the bolts off and toss the cylinder in the trash.
#3 |
1992 SL2
1992 SL2
so the threaDS ARE ONLY ON THE CYLINDER, NOT ON THE PLATE FOR WHICH THE CYLINDER IS MOUNTED?
#4 |
Or... something like this
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes |
#5 | |
![]() Quote:
If its like the other drums Ive worked on, the two bolts go through the sheet metal backing and the thread is in the cylinder- the part your about to replace... |
#6 |
If the bolt HEX (the part the wrench goes on) is ROUNDED, then cutting the bolt head off will work as enough of the threaded portion of the bolt will remaing to allow you to grip it (presoaked with PB Blaster NOT WD40 first) to unscrew them. If the threaded portion of the bolts are actually STRIPPED, you have a larger problem.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#7 |
But if your replacing the whole wheel cylinder- then theres no issue I can foresee?
#8 |
![]() Join Date: Feb 2007
Vise-grips.
#9 |
BFH.
or push the car off a cliff and buy something else. ![]()
1996 Dodge Avenger ES: 2.5L V6 |
#10 |
1992 SL2
1992 SL2
I used Vise grips, and held a torch there for about 5 minutes, and i damaged the bolt worse, I have no grinder, so I'm going to try to chisel off the bolt heads, then pull out the old cylinder.
Bookmarks |
Stripped bolt??? | duganator9 | S-Series Tech | 18 | 11-16-2007 07:22 PM |
stripped bolt, someone help! | cmac212 | S-Series Tech | 9 | 01-15-2007 10:03 PM |
Stripped Interior | sl1budgettuner | S-Series Mods | 24 | 06-27-2005 08:04 PM |
Stripped battery bolts | schultp | Miscellaneous Tech | 7 | 12-30-2004 01:02 AM |
How to unbolt 2 rounded(stripped) bolts???? | freakerz | S-Series Tech | 8 | 11-16-2004 10:24 AM |
